So i burn oil and i have white smoke coming out my exhaust
Old 11-22-2008, 05:17 AM
Redprelude98's Avatar
Default So i burn oil and i have white smoke coming out my exhaust
I do burn oil and i have white smoke coming out of my exhuast can someone tell me what this means because it doesnt even burn that much, i thought it was burning a lot for a while and then i looked and i had two really bad oil leaks but yeah anyway can someone help me out here please
Old 11-22-2008, 06:02 AM
vinuneuro's Avatar
White smoke is coolant being burnt. Most likely headgasket. Do a leakdown test.
Old 11-22-2008, 07:23 AM
ok so seriously how do i go about doing that i am not like the greatest at that
Old 11-22-2008, 07:28 AM
Derek1990's Avatar
white smoke is coolant. Its your head gasket
Old 11-22-2008, 07:29 AM
well it is a whiteish blue kinda
Old 11-22-2008, 07:30 AM
so i am thinking it is like something to do with my valve seals or something maybe?
Old 11-22-2008, 07:32 AM
well hoping i guess because i am pretty sure that that is a little bit cheaper than a freakin head gasket
Old 11-22-2008, 07:58 AM
Kronn 98SH's Avatar
take it to your local dealership, they can do the leakdown test.
Old 11-22-2008, 08:08 AM
preluderemis's Avatar
your not wrong...but burnt vavles seals would only result in oil being burnt and a dark blue smoke...not white smoke from coolant
Old 11-22-2008, 09:21 AM
vinuneuro's Avatar
How to do a leakdown test
Old 11-22-2008, 09:34 AM
ShoofIsLudin's Avatar
price on a headgasket itself is less than $100, its the labor that places charge to do it that adds on so much money to the bill.
Leakdown requires an air supply from a compressor
Old 11-22-2008, 04:44 PM
so just saying that i do have to replace my head gasket does anyone have any ball park figures that i would be looking at for price wise and what else would i need to replace so that something else doesnt wear out quick?
Old 11-22-2008, 04:50 PM
that is a what if? because i was told that my car would also be running like crap and idle really rough??????
Old 11-24-2008, 01:31 PM
so yesterday i had my brother rev up my motor while i looked at it and the smoke is white, but i look in my radiator and it is still full of antifreeze and another thing it doesnt run hot at all it is below the middle by like 2 little tics, so is that still my head gasket or what? i am so confused and i do burn oil like 1-2 quarts per oil change
Old 11-24-2008, 01:45 PM
it was just a little bit, not bad really at all but it still scares me
Old 11-24-2008, 03:34 PM
atarigamer01's Avatar
Post
could be your piston rings are fried, you may want to consider that also.
Old 11-24-2008, 05:25 PM
now tell me this what all will i have to do whenever i change the piston rings or have them changed should i say, will i have to replace like everything else and pretty much rebuild my motor completely or can i replace my piston rings and valve seals or what would you reccommend?
Old 11-25-2008, 08:20 AM
well, Im just saying, you may have to. But from what your saying thats what it sounds like. Look at it like this, if you're going to change your head gasket, the pistons are right there in front of you. So it wouldn't hurt to maybe change the piston rings, just for peace of mind atleast. Just take off the oil pan, pop em right out from under neath. You may need a friend to help you. Maybe change the water pump and timing belt also if you want to go all out.
Old 11-25-2008, 08:22 AM
vinuneuro's Avatar
Do a leakdown test. Replacing parts blindly is foolish.
Old 11-25-2008, 08:37 AM
moderator emeritus
98vtec's Avatar
we cant give you any real answers unless you get your hands dirty or pay someone to get their hands dirty to figure out the problem.
Old 11-25-2008, 10:42 AM
Widebody93's Avatar
WELL SAID
mafia
08-17-2007 05:58 PM
VvPeachyvV
14
12-09-2004 06:38 AM
1990civicsi
08-08-2004 06:33 PM
Layziebtnh055
10
04-16-2004 02:22 PM
extrmeboost
06-13-2003 08:00 AM
Quick Reply: So i burn oil and i have white smoke coming out my exhaust
