gears feel notchy and 5th gear grind
Old 03-08-2005, 07:58 AM
korndog's Avatar
Default gears feel notchy and 5th gear grind
Well all of my gears feel notchy when you shift into them and my 5th gear has started to grind. I put gm synchromesh fm as everyone on here recomended and the gears still feel notchy and the fifth gear grind is still present from like 2,700rpms and up. Now most ppl i have seen on here claimed gm synchromesh to clear away notchyness and gear grinds. Could something else be the problem?
This is very annoying as it caused me to lose a potential sale for my car today when they guy shifted into 5th and got the nice crunch. BTW my car is a 95prelude v-tec.
Old 03-08-2005, 08:18 AM
AzCivic1.6's Avatar
are you sure you got the right synchromesh?
Old 03-08-2005, 08:22 AM
korndog's Avatar
Default Re: (AzCivic1.6)
Yea I'm pretty sure of it.
Old 03-08-2005, 09:19 AM
eluder33's Avatar
Default Re: (korndog)
my tranny is the same way, the shift forks are bent, there was a service announcement that honda put out a while ago about it. Its a commo problem for 4th gen forks to bend and 5th gear to grind new syncros and fork are the only fix pick up the newest issue of honda tuning and there is a good article about the H22 tranny(pretty much the same thing) and how to rebuild it, the pics are helpful in understanding the problems as well
Old 03-08-2005, 10:19 AM
AzCivic1.6's Avatar
damn, sounds like thats ^ the problem.
Old 03-08-2005, 10:39 AM
korndog's Avatar
Thanks for the word of advice, would anyone know where to get these parts from (shift fork and synchro)?
Old 03-08-2005, 10:45 AM
Fly1865's Avatar
http://www.slhondaparts.com , http://www.hondaautomotiveparts.com
Old 03-08-2005, 11:01 AM
eluder33's Avatar
Default Re: (Fly1865)
buy some better aftermarket carbon steel syncros if you plan to keep the car anylonger and/or if you want to be nice to the buyer
Old 03-08-2005, 11:15 AM
korndog's Avatar
I got my car from Japan, so it is rhd with the jdm engine and tranny. Can i still use the parts for a usdm tranny?
Old 03-08-2005, 11:18 AM
eluder33's Avatar
yes
Old 03-08-2005, 12:35 PM
korndog's Avatar
Default Re: (matty c)
thanks
Old 03-08-2005, 06:34 PM
HPrelude0926's Avatar
Default Re: gears feel notchy and 5th gear grind (korndog)
4th gen. ludes are known to grind 5th. Its a major problem with them. When I had my USDM tranny it would always do that. I dont believe that the USDM ludes tranny's are anywhere as good as the JDM ones. I have a JDM tranny in it now and its not notchy at all and 5th never grinds.
Old 03-08-2005, 07:14 PM
JDMF22B's Avatar
Default Re: gears feel notchy and 5th gear grind (HPrelude0926)
my 3rd through 5th grinds.... actually its more like..... 3rd grinds, 4th rubs (bad, but not a grind), and occassionally 5th grinds..... but if i slam it in theres no grinding -_-
Old 03-09-2005, 12:50 AM
Boarderx192's Avatar
Default Re: gears feel notchy and 5th gear grind (JDMF22B)
Wich Hondatunning mag? I went to the store today for it and theres only the "civic slide" or something like that. Nothin bout the H22 tranny in there.
Old 03-09-2005, 03:52 AM
RemerLex11's Avatar
Default Re: gears feel notchy and 5th gear grind (Boarderx192)
same thing happens to me im too lazy to change the sychros but double clutch into 5th gear and your problem is solved
Old 03-09-2005, 06:16 AM
jackstands's Avatar
Default Re: gears feel notchy and 5th gear grind (Matt5745767)
Before all that, maybe try to bleed the clutch, that might temporarily ameliorate the problem, buying you more time. Also, rev-matching preserves your synchros.
Old 03-09-2005, 07:23 AM
korndog's Avatar
yea which honda tuning magazine is this in?
Old 03-09-2005, 07:47 AM
Power Rev Racing's Avatar
Just put a H22 in my civic and 5th gear grinds. It even grinds if i am 30 miles per hour. Sucks really bad.
Old 03-09-2005, 08:03 AM
machine4321's Avatar
ive got a 5th gear shift fork and 5th gear set on order for my usdm tranny..ill let you guys know how it all goes when im done
Old 03-09-2005, 08:05 AM
korndog's Avatar
Default Re: (machine4321)
How much did it cost you?
Old 03-09-2005, 01:54 PM
Ya how much does it typically cost to have the syncros replaces?
Old 03-09-2005, 03:18 PM
RemerLex11's Avatar
Default Re: gears feel notchy and 5th gear grind (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">Just put a H22 in my civic </TD></TR></TABLE>
damn i bet that thing moves
Old 03-09-2005, 05:10 PM
eluder33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boarderx192 &raquo;</TD></TR><TR><TD CLASS="quote">Wich Hondatunning mag? I went to the store today for it and theres only the "civic slide" or something like that. Nothin bout the H22 tranny in there.</TD></TR></TABLE>
its in the one right after that, the newest issue. I think its april or may, it sas right on the cover "H22 transmission rebuild"
Old 03-09-2005, 11:54 PM
korndog's Avatar
Default Re: gears feel notchy and 5th gear grind (matty c)
Thanks picked up a copy today. **** look very confusing to me. lol who would like to fly out here and help me with this?
Old 03-10-2005, 12:01 AM
95greenlude's Avatar
what kind of synchromesh? and how much would i need?? i'm developing the 5th gear drind too, so i want to fix it
Quick Reply: gears feel notchy and 5th gear grind
