oil light flashing??
why would the oil pressure light start flashing... im topped off on oil it started flashing when i was at a light then it would just keep flashing until i turned the car off...
Re: (m3dia_lab)
well, you could try actually checking the connection and see if it's loose. Mine was doing that for a long time, full oil and everything. I looked up under there and sure enough.. the connection was loose as hell! Wouldn't hurt to peak up in there and take a look.
Mine does it too... It did it on the H23 that i had in the car and now its doin it in the H22, im goin to check the connection, and if that doesnt work then im gonna replace the sending unit, and then if that doesnt work that i guess that i will have to replace the oil pump
Re: (PWRDbyHseries)
Sorry to post on here I dont have a prelude I have and Integra and its doing the same thing thats happening to you.....my oil light from the dash starts blinking like crazy and then my car shuts off....I'm thinking is something with the oil pressure but I dont even know where the oil pump is or where the oil pressure sending switch is. I've read your post hopefully there in the same place...
Re: (dallas_racer2004)
Just because you have a full crank case of oil, doesn't mean you have pressure. You can replace the sensor, but I would
IMMEDIATELY STOP DRIVING YOUR CAR
And check on that oil pump.
Re: (xTravBx)
But where is the Oil PumP located and the oil pressure sending unit...Do I have to take off my oil pan to see the oil pump because i dont even know where to start...humm
I found the oil pump DAMNNnnn You Have to Take Everything Off SNAPS........Well i'm going to take off my oil pan to see if the pump is clogged or something if not i'll replace it all....If anyone could shed some light on this Please comment THANKS.......
Re: (PWRDbyHseries)
I had the same prob. on my 5th gen, Wasnt the pump it was sending unit, Replaced sending unit and problem still happened, replaced it w/ an aftermarket sending unit and havent had the problem since, even though stock wire is still hooked up, Its the strangest thing, Good luck with it
Re: oil light flashing?? (m3dia_lab)
well my oil light started flashing today so i imediatly turned it off and popped the hood and there was oil sprayed everywhere. It seems to be coming from the back side of the block somewhere. Is there anythign pretty comman that would blow and cause oil to shot everywhere?
Re: oil light flashing?? (pprowler6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprowler6 »</TD></TR><TR><TD CLASS="quote">well my oil light started flashing today so i imediatly turned it off and popped the hood and there was oil sprayed everywhere. It seems to be coming from the back side of the block somewhere. Is there anythign pretty comman that would blow and cause oil to shot everywhere?</TD></TR></TABLE>
yes. it's the oil cooler seal. couple bucks job.
well that would make sense to why he was loosing pressure... and speaking of oil lights why is it so hard to get girls to understand how imperative it is to STOP when they see the oil light.... "but i had no where to stop and I couldn't be late for work.." blah blah blah.. Stop or the car will poop and make you stop.. LoL. Sorry i'm frustrated with girls.
MyUsernameName
06-15-2017 02:06 PM
