Prelude won't rev past 3k and smokes white
Old 10-22-2008, 06:20 AM
GreatShamanGT's Avatar
Default Prelude won't rev past 3k and smokes white
Car was "rebuilt" by a guy on here named chucky who claimed he could do the work but brought it back to me running funny. Rebuilt motor is in the car. Car starts and idles...it won't go over 3k. It was just bailed out of a shop and they fixed every possible little problem that he left not done including a oil leak and exhaust leak. compression is good in 3 cylinders and one is low according to the shop but my Dad is saying they said all four are good and no blue smoke. Car smokes white and eventually clears out due to whatever the issue is. The car threw a rod to begin with which started this whole situation.
Old 10-22-2008, 06:43 AM
moderator emeritus
98vtec's Avatar
Default Re: Prelude won't rev past 3k and smokes white (GreatShamanGT)
ok lets go through the list of things you need to give us:
CEL's?
what all was rebuilt?
have you contacted the guy who did the motor?
white = coolant which suggests headgasket
Old 10-22-2008, 07:36 AM
Exedy clutch
Type S pistons
Eagle rods
new dizzy
new axel
new bearings/gaskets
new valves
No check engine light.
Old 10-22-2008, 07:39 AM
moderator emeritus
98vtec's Avatar
Default Re: (GreatShamanGT)
verify cam timing
perform compression or leakdown test. Preferably leak down.
was a valve job done to the head with the new valves?
alswizzo
01-24-2013 05:27 PM
jtfc3s
04-18-2007 01:04 PM
afmoose7
07-03-2006 10:04 PM
SM00TH976
05-18-2006 10:55 AM
aut0tek
05-31-2004 10:51 PM
Quick Reply: Prelude won't rev past 3k and smokes white
