NO SPARK - 1990 2.1 Si Auto - extenstive troubleshooting, electrical problem?
1990 Honda Prelude 2.1 Injected Auto - NO SPARK
I am helping my friend troubleshoot his car that has no spark. He bought the vehicle
not running and upon doing a compression test found that the headgasket was blown. It
also had some bent valves so he replaced the cylinder head, head gasket, timing belt
and water pump and put the motor back together. After everything was back together,
he put a jump box on it and started it up. The motor ran fine for ~10 seconds and cut
out. The car's shutting off seemed to correspond with him moving the connections/jump
box. I suspect either the + and - cables touched each other, or he simply lost
connection with one of the cables. The car would not re-start and it was found that
no spark was coming from the coil. The ECU fuse and the clock fuse (both in the
underhood fusebox) were both found blown. The fuses were replaced and have not blown
again. Still no spark.
We have several repair manuals for this car, and we've gone through the "no spark"
troubleshooting they suggest.
Since then, we have tested/swapped:
ignition coil (resistances)
distributor
ECU power and ground sources
ALL fuses
main relay and wiring
ignition switch and wiring
coil/plug wire resistances
TDC/CYL/Crank sensor resistances and wiring to ECU
wiring from ECU to other sensors (intake air temp, coolant temp, etc)
swapped ECU for another from 1990 2.1 auto
One component we couldn't test is the radio condenser, a small square device mounted
to the ignition coil with two wires leading off of it. It prevents ignition system
signals from creating unwanted noise on the radio. The repair manual says if this is
shorting internally that it will cause a no-spark symptom. Unfortunately, a
capacitance tester is needed and we don't have access to one. We do have a spare
radio condenser (from the junkyard) and swapped that with no luck though.
After all of this, we took the car to the local Honda dealer to have them
troubleshoot it. They called and said they reconfirmed our tests and determined that
our components were good, and it must be a faulty/shorting wire. We brought the car
back and began more wiring tests.
We peeled back the insulation and inspected the wires and connections inside the
engine compartment and leading into the firewall and to the ECU. We found no damaged
wiring and re-wrapped the wiring.
At some point we noticed a "hot electric" odor from the engine bay and sniffed around
and found that the alternator was hot to the touch with the key off. We re-checked
the alternator wiring and found that the BLK/YEL wire to the alternator, which should
be hot when key is ON or START, had continuity to ground when the key is off. We then
found that the positive battery cable has continuity to ground when the battery is
unhooked. Does it seem our system has a hot wire shorting to ground? BTW, the car
still gets no spark even with alternator unhooked.
STRANGE BEHAVIOR
The car is now back together with most of the original parts. We have noticed some
strange things during the last few days of testing:
Car has no spark, however if key is turned to ON, then off (never to START) a single
spark is produced from the coil wire when the key goes to OFF. This was observed many
times seems to happen only with one out of three igniters we swapped.
We took each engine bay fuse out one a time and tested each side of the circuit for
continuity to the positive battery cable (with the battery out). Each gave continuity
only to one side, except for the headlight fuses. There is one for left, one for
right. However, when the headlights are on and we pull one side's fuse, that side
dims but does not go completely out. If both headlight fuses are pulled, both go
completely off. We tried the test of a 1991 Accord and each headlight goes out
totally when its fuse is pulled.
Another test we performed was to pull each fuse and replace it while checking for
continuity between + battery cable and ground (with the battery disconnected). The
meter changed very slightly for some fuses, but for the most part stayed near 0. We
found that the meter jumped to about 600 when we pulled just the "seat belt
retractor" fuse from the underdash fusebox. The car has regualar seatbelts, not the
kind that move when you open/shut the door. Does this mean something?
OTHER CONCERNS
What would happen if you touched + and - battery terminals while the car is running?
What caused the ECU fuse and clock fuse to blow? (Perhaps the clock fuse was blown
before we started work on the car, but obviously the ECU fuse had to be good for
those 10 seconds when the car was running.)
We are near our wits' ends with this car. We don't have a superb understanding of
electrical circuits, but we can read a schematic and (sort of) use a multimeter. Can
you think of anything we haven't yet?
Thanks for any help you can offer!
distributor
ALL fuses
STRANGE BEHAVIOR
OTHER CONCERNS
