New Transmission How Much Fluid??
Old 04-06-2013, 12:19 PM
jmh4bb6's Avatar
Default New Transmission How Much Fluid??
Im replacing the tranny in my prelude soon and need to know how many quarts of atf I need! I know to flush it i need about 2 quarts. Its also an auto. Any help is appreciated!
Old 04-06-2013, 01:44 PM
P. Hunter's Avatar
Default Re: New Transmission How Much Fluid??
well when you got the trans im sure the torque converter came with fluid in it BUTTTT you can always make sure of it.. after you fill the trans check to see the level. make sure its full. jack the car up so the wheels are off the ground and get trans to go into full lock up (have it shift through all the gears), this will get the fluid to get into the converter. check the fluid again and see if you need to add any
Old 04-06-2013, 06:01 PM
Apex1972's Avatar
manual swap
jmanuel
04-24-2014 09:48 PM
hamadiscool
Honda Civic (2001 - 2005)
06-05-2007 08:21 PM
St3v3
02-11-2007 05:09 PM
Cypher0117
05-03-2005 06:47 PM
mystikz2002
Acura TL, RL & ZDX
12
01-20-2005 09:22 AM
Quick Reply: New Transmission How Much Fluid??
