Stock H22 intake manifold idea
Old 05-06-2010, 12:16 PM
big_boi_lude's Avatar
Default Stock H22 intake manifold idea
so I was sitting here playing with my stock IM cause i just installed a skunk2 on my motor with has nothing other then hytech reps, ecu and velocity stack and 2.5inch all the way out exhaust, based on feel high end its great, but i lost alot of low end torque and throttle response its not great, now im sitting here looking at the stock manifold and I know alot of ppl remove the butterfly valves from the plate, but has anyone ever tried just removing the plate completely? mean you would decrease the air volume in the chamber, but then the manifold looks more towards the likes of the euro r, I know, i said "looks",
im actually goin to try this as I have a h22 in a 3rdgen so my manifold is easy to remove. I know nothing about intake manifolds so I thought putting this out there to see what you guys think
Old 05-06-2010, 01:00 PM
Kronn 98SH's Avatar
Default Re: Stock H22 intake manifold idea
Use the Search feature. The topic of removing the butterfly plate is well documented.
Old 05-06-2010, 04:45 PM
gstrudler's Avatar
Getting rid of the butterfly plate will give you the same feeling you have with the S2, better top end with sacrifices down low.
Old 05-06-2010, 05:59 PM
q16racer's Avatar
not really.
________
COLORADO MARIJUANA DISPENSARIES
Old 05-06-2010, 06:11 PM
gstrudler's Avatar
I'm not saying they will produce the same graph, but the overall characteristics would be similar unless I am terribly misinformed.
Old 05-06-2010, 06:16 PM
q16racer's Avatar
too much internets
________
Vaporizer Help
Old 05-07-2010, 06:44 PM
gstrudler's Avatar
Haha, too true. Am I incorrect in assuming that both will generally lose low-end torque but make gains in the upper rpm range compared to stock?
Old 05-08-2010, 12:04 PM
viper_boy403's Avatar
Originally Posted by q16racer
too much internets
teeheehee, nice to see you around here
It will have gains across the entire RPM range if you tune it. Not sure about running on the stock ECU
Old 05-10-2010, 05:51 AM
nus_dogg's Avatar
Or, you can get a Blacktrax Plenum spacer(IABs deleted) to replace your stock IAB spacer. Thats what I'm running right now.
shocker911
14
02-23-2014 09:00 PM
Jsarv
05-18-2011 12:43 AM
Lude-acris
01-19-2005 04:10 PM
MrMike
05-20-2004 03:14 PM
Quick Reply: Stock H22 intake manifold idea
