IS my Engine in danger? or is this not serious?
Ok recently about 2 weeks ago i installed a I/E/H the weather has been a little cold but the install went perfect, but now i've been hearing this knocking sound kinda, as if there was an empty spray can in my engine, it only happens in the cold weather and when the car is at idle, after the car has been on for more than 30 minutes and been driven its fine theres no noise at idle, all my coolant levels are fine, my oil is fine, i bought the car with 27050 miles and now have 29562 im gonna be doing an oil change soon, but im wondering if this problem is more serious? i also drive my car hard comin home at 100+ in the highway.. any ideas?
New User
Re: IS my Engine in danger? or is this not serious? (99Interlude)
What grade of fuel are you using? And how often do you drive you car @ 100+ on the highway coming home?
New User
yep ever since than the noise started no engine codes no nuthing.
Re: IS my Engine in danger? or is this not serious? (laughin2.2)
detonation say what ?? what should look for when i take it off burnt? or something.
New User
Look for specks of white on the elctrode.
This may help also. http://www.ngksparkplugs.com/techinf...q/faqread2.asp
Nope checked no white powder, everything is A ok, i started up the car no noise... but no detonation so.. i dont know what it could be. by the i dont have a heatshield on.
Re: IS my Engine in danger? or is this not serious? (jgrotkier)
I dont know its not a continuous thing, i mean right now i turned the car on fine no prob, full tank of gas no noise.
well considering that it only does it when its cold, I still think its your vavles.
New User
sounds like a valve problem to me...when it's cold they open a little more then when it's warm...not sure tho
New User
Re: IS my Engine in danger? or is this not serious? (LudeBehavior)
yeah if its at idle, you may need to get your valves adjusted at honda or.....my ticks too but nothing from the normal h22. There should always be like a soft clicking from the motor. I think its the injectors clicking on and off....
da9pwnsu
12-07-2005 07:32 PM
MrEG6er21
14
03-24-2004 10:33 PM
