How many teeth on timing belt between TDC arrows on cam gears?
I just put a new timing belt on my car, but it seems pretty loose on the top. How many teeth are supposed to be on the belt between the two top arrows?
I counted 14 on mine, but it is really loose.
Re: (snobordboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi »</TD></TR><TR><TD CLASS="quote">Did you follow the tensioning procedure properly? Are the cam gears and crank gear set at tdc properly? auto or manual tensioner? These are things we need to know.</TD></TR></TABLE>
It is a 97 prelude w/ H22. Everything is set properly at TDC. And after 8 revolutions everything still lines up. I stayed with the auto tensioner. Currently the auto tensioner still has the holder on it...I have not taken it off to put tension on the belt yet.
Re: (slammin86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammin86 »</TD></TR><TR><TD CLASS="quote">
Currently the auto tensioner still has the holder on it...I have not taken it off to put tension on the belt yet. </TD></TR></TABLE>
that would be why, put tension on the belt, rotate a few times, and double check to make sure you are still where you are supposed to be.
Re: (Giant_Bean)
It is a 97 prelude w/ H22. Everything is set properly at TDC. And after 8 revolutions everything still lines up. I stayed with the auto tensioner. Currently the auto tensioner still has the holder on it...I have not taken it off to put tension on the belt yet. </TD></TR></TABLE>
I figured it out. I still had the bracket in the auto tensioner holding it while those pics were taken. I took out the bracket and rotated the engine a few times and everything tightened up.
You were right.
You were right.
scoob8000
12-19-2011 11:57 AM
Dased530
08-07-2005 04:52 PM
