50 Amp fuse blow in my Prelude 5th Gen
Old 12-16-2013, 01:48 AM
sramdon's Avatar
Default 50 Amp fuse blow in my Prelude 5th Gen
I have a 5th Gen Prelude. I came to a stop light and my car cut off. After long investigation, I found a underhood fuse labeled "Fuse Box" 50Amp blown.
I ended up using the 40Amp from my power windows to allow me to limp back home. I need to figure out the reason for this fuse blowing so that it doesnt blow while I am on a long trip.
What does this "Fuse Box" fuse protects?
My mechanic suggests that it is definitely something under the hood, because 50A carries a lot of electricity, so a large possibility might be the battery touching the hood of the car. Have any of you guys had the fuse blow on you? I have a 10 hour trip coming up and I need to make sure that my Prelude is reliable.
Old 12-17-2013, 07:39 AM
professorman's Avatar
Default Re: 50 Amp fuse blow in my Prelude 5th Gen
I found this tread on PreludeOnline.com. The #36 "Fuse box" 50 Amp fuse (WHT/RED) protects underdash fuse/relay box No. 1, 4, and 6 fuses, which are: Underdash #1: ATTS Control Unit (WHT/BLU); Underdash #4: Immobilizer Control Unit (WHT/GRN); and Underdash #6: Driver/Passenger seat heater (WHT/BLK) (Canada only).
Trace the wires and search for a short somewhere.
Old 12-17-2013, 11:34 AM
sramdon's Avatar
Thanks, I will look into it, my under dash fuse box cover was off, there might be possible moisture and water down there since it was snowing that day. That could be a possible reason for the short.
Old 12-19-2013, 04:49 PM
minilogoguy18's Avatar
A blown fuse is only the result of a short to ground before the load or a load added to the circuit that draws more amperage than the fuse is rated for, common example of this is aftermarket crap accessories being spliced in.
monsterCHILD
01-06-2011 04:28 PM
si0385.
20
04-17-2006 08:12 AM
RemerLex11
07-14-2005 02:25 AM
sloweh3
10-31-2003 04:58 PM
4doorH22
Audio / Security / Video
09-06-2002 07:34 PM
Quick Reply: 50 Amp fuse blow in my Prelude 5th Gen
