HELP NEEDED! Brake pedal will not hold pressure.
Old 01-31-2016, 07:01 PM
NeGraVity40's Avatar
Default HELP NEEDED! Brake pedal will not hold pressure.
Hey there! I'm going to give a small summation as to the situation I have with my brake system and hopefully someone has some ideas! I started building a 4th gen 92 prelude SI as a track/rallyX car. Brake pedal had always felt normal when it was just a daily driver until the last few months and it began to feel soft. I went to put on track pads, drilled/slotted rotors, and all 4 new calipers and when on a test drive the brake pedal still felt the same. Later that week I replaced all brake lines with steel braided lines and suddenly the pedal would be soft and sink to the floor. No more air is coming out when bleeding so I suspected a faulty master cylinder. Bench bled the new reman master, installed it, and bled the system. The pedal felt roughly 5% better. The pedal is somewhat squishy and always feels good at first and then slowly sinks until it hits the floor whether driving or at a stop.
There are no leaks, all calipers are new, master was replaced with a reman, and the only thing I have not touched is the ABS unit. The car is fully stripped out and has an ABS unit under the hood but the ABS control module is removed. Could the ABS unit be suspect (aka have air trapped inside) or possibly the the reman master may be a faulty replacement and I should try a new one? Is there a special way to bleed the ABS unit (I have tried opening the bleeder on it to bleed it with no avail and have heard I may need a special computer/scanner) or eliminate it altogether? Please help lol!
Old 02-01-2016, 05:53 AM
spray004's Avatar
Default Re: HELP NEEDED! Brake pedal will not hold pressure.
It's definitely air in the lines. Some cars are a pain to bleed (my F150 is a pain), others are easier.
Old 02-01-2016, 09:52 AM
I have tried bleeding it, driving it for a while, bleeding it, driving it, and so on a few times and only get pure, clean fluid with no air. I have been using the proper RR, RF, LR, LF (I can't remember the exact procedure so sorry if this is inaccurate) procedure too. I'm not sure what else to try.
Old 02-01-2016, 11:39 AM
motoxxxman's Avatar
I've had this problem before, it's almost definitely air in the ABS unit. loosening the bleeder on the abs unit probably introduced more air too. the only way to bleed it is to have it be functional and hammer down on the brakes on a slippery surface to activate it, it's a self bleeding system for the most part. or you can have a dealer bleed it, which requires a special computer, and it has to be functional for that too.
I vote you just remove it and install an oem proportioning valve. eliminate any future issues. you obviously dont want the abs for racing, so might as well look at it as weight reduction too.
Old 02-06-2016, 06:40 AM
I had a feeling this would be the case. Thanks for your help! I have another question then. Where can I find an OEM proportioning valve so I can just eliminate the ABS Unit altogether?
Old 02-06-2016, 09:29 AM
Actually just found one on Amazon.com for about $167 with no picture; however; it says it is compatible for the 92. Is there anywhere else you would recommend looking other than the dealer?
Old 02-06-2016, 11:50 AM
motoxxxman's Avatar
preludepower.com or any of the prelude facebook groups. used is perfectly acceptable
Old 02-08-2016, 08:42 AM
Moderator
snobordboy's Avatar
Keep in mind, all of your brake lines will be different as well for the front of the car, as well as a different master cylinder.
If you can find a 92-95 S model, with the single cam engine, they did not have ABS from the factory, so they have the correct prop valve and lines to delete ABS. I removed the whole system from a used car, and it works perfect, all factory parts.
You can bend new custom lines, but you still need a prop valve with the correct split, and the right master cylinder.
Old 02-20-2016, 05:10 AM
Ah thanks for the help guys! Much appreciated!
Old 01-05-2019, 01:49 PM
KILLluminati410's Avatar
I'm having a problem with my recently purchased 97 prelude. I just installed new rotors and pads plus rear calipers since driverside rear seems like it hasn't worked in years and passenger side piston would not retract to put new pads in.
I installed everything and still can't get my driverside caliper to work and now I have a leak right by the firewall (please see pics). if anyone can help please email me at hondatic410@hotmail.com
OttawaGSR
07-05-2011 10:15 PM
elnoyl
07-27-2009 10:22 AM
USDM-EK4*
04-04-2008 07:50 PM
JZA70
11-14-2006 11:16 AM
Rboosted717
08-01-2001 12:14 PM
Quick Reply: HELP NEEDED! Brake pedal will not hold pressure.
