HELP! Broken Lug on a 5G
New User
I was rotating my tires today and when i was tightening down the lug it snapped off. I was even being careful and trying not to over tighten it but I guess I'm just too strong . What is the easiest way to replace the lug and is there an aftermarket one that would be stronger? Please respond soon as I'm not that comfortable driving around missing a lug nut.
Re: HELP! Broken Lug on a 5G (burn)
You can just get a replacement at about any autoparts store.. NAPA is good with that stuff.. I snap mine all the time and always have extras around.. Make sure to bring your old one when you go to match it up..
Your fine with 4 lugs, just take it easy.. =~)
just hit the old one with a hammer and it will knock out.. when putting the new one on, slip it in and put a lugnut on the stud and tighten it down to pull it threw the hub, you might have to stack a couple of washers.. Good luck
New User
Re: HELP! Broken Lug on a 5G (Honda318dx)
ahhggg!!!!
ok...tried tonight to remove it...
1. took the wheel off
2. took the rotor off
3. took the castle nut of the axle
4. the manual told be that i had to remove the entire spindle and have the hub pressed apart by a hydrolic press so that i can hammer out the lugs!!?
318 - am i missing something complete obvious here?
