H23 Manual Tensioner on H22A, what timing belt?
Old 02-02-2003, 05:20 PM
93LudeVtec's Avatar
Default H23 Manual Tensioner on H22A, what timing belt?
What you need:
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM
I did a search and these are the parts that are needed, is the timing belt included in these parts or do I need a new one? If I do...do I need a H23 timing belt or an H22? Anyone know the part #. Thanks, Andrew
Old 02-03-2003, 04:30 AM
CHK4TIX's Avatar
Default Re: H23 Manual Tensioner on H22A, what timing belt? (93LudeVtec)
just use the h22 belt
Old 02-03-2003, 09:33 AM
paulzy's Avatar
is it really that hard to work with the auto tensioner that makes everybody convert over to the manual tensioner setup?
Old 02-03-2003, 09:40 AM
Flavour's Avatar
Default Re: H23 Manual Tensioner on H22A, what timing belt? (1320development)
i've had 2 autotensioners fail. once causing damage, once i caught it in time.
i will be doing the swap the next time my current one fails.
and yes, use the h22 belt.
Old 02-03-2003, 02:09 PM
Smurfylude's Avatar
Default Re: H23 Manual Tensioner on H22A, what timing belt? (CHK4TIX)
The H23 and H22 belt are the same. I checked with Honda.
Old 02-03-2003, 03:07 PM
96SR-V's Avatar
Default Re: H23 Manual Tensioner on H22A, what timing belt? (Sushi X [TCL])
I used the H22 belt on my conversion....Damn it was a tight fit...
Old 02-03-2003, 03:12 PM
rokestah's Avatar
Probably a stupid question, but what is an "auto" and "manual" tensioner?
Old 02-03-2003, 03:27 PM
96SR-V's Avatar
Default Re: H23 Manual Tensioner on H22A, what timing belt? (rokestah)
Auto tensioner uses a spring I believe to take up slack on the timing belt wheras a manual is tightened manually, pls correct me if I'm wrong?
Old 02-03-2003, 04:07 PM
satan_srv's Avatar
Default Re: H23 Manual Tensioner on H22A, what timing belt? (96SR-V)
Yeah, you would have to tighten manually as your timing belt loosens over time. However it's pretty easy compared to servicing an auto-tensioner.
Old 02-03-2003, 06:15 PM
Flavour's Avatar
don't forget auto are pieces of garbage, while the manual is much less prone to a catastrophic failure...
[Modified by Flavour, 10:16 PM 2/3/2003]
H22LUDE808
03-07-2008 09:18 PM
h22sedan
11-08-2006 05:20 PM
h8trix
08-11-2005 08:36 AM
SilverEk3dr
01-29-2003 11:27 AM
Quick Reply: H23 Manual Tensioner on H22A, what timing belt?
