H22A resistor box HELP!!
I need to know how to wire up my resistor box for my h22 civic. I have the four wires that are a different shades of yellow separated from each other on my 92 civic harness, and I just need to know where to solder them. Help would be greatly appreciated. Thanks, David
Re: H22A resistor box HELP!! (esedulerp5tenin)
Thanks a lot man, that diagram will help out a lot! A picture is worth a thousand words.
Re: H22A resistor box HELP!! (turbo_d)
So the four thicker yellow wires are soldered to the black wires on the resistor box. And the lighter, thinner yellow wires are all soldered together, and then soldered to the black wire on the resistor box. Correct?
yup you got it, except the colors might be diff. so.... the 4 common colored from the injectors go to the 4 common wires to the resis box.
then the four commons from the harness get soldered together, then to the single wire to the resis box.
elmalouno
10
07-07-2004 12:59 PM
