F20b won't crank need help asap!!
I just did the f23 crank and rods in my engine and now it won't crank got fire, fuel, and timing is set it just won't start. The car was running before. It had a spun rod bearing and idk why it won't start now. Any help would be greatly appreciated thanks.
Re: F20b won't crank need help asap!!
Yea it turns over it's gettin spark and fuel I can smell it. It just won't fire up I tried resetting the timming it has crower stage 2 cams also it's also been tuned befor I did the crank swap idk if that has somethin to do with it
It was still running when I took the engine out. I didn't do anything different it just won't start I did a compression test also and it has 210 psi all the way across. I just ain't had so much trouble to get not to crank
