EGR valve question
Old 05-25-2006, 07:23 PM
TheAccordGuy's Avatar
Default EGR valve question
It is me? If you disconnect the EGR valve or any sensor for that matter isn’t the ECU supposed to automatically throw a Cel. When I unplugged my EGR valve just to check if the person who did my swap wired it up correctly. I got no check engine light. I do get a check engine light code 12 which is my EGR when I hit highway speeds. Is this normal.
Old 05-25-2006, 08:16 PM
DIRTYsouthBB6's Avatar
if you got a troublecode from it, then it sounds normal to me
Old 05-25-2006, 09:10 PM
mr_carman007's Avatar
Default Re: (DIRTYsouthBB6)
yep what he said
Old 05-26-2006, 04:59 AM
I understand but why does the egr not throw a code when I unplug it.
Old 05-26-2006, 08:04 AM
Hawkze_2.3's Avatar
Default Re: (TheAccordGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">I understand but why does the egr not throw a code when I unplug it.</TD></TR></TABLE>
The EGR will not instantly throw a code. You have to drive around a little bit for the sensors to realize something is wrong...
Old 05-26-2006, 10:12 AM
That the response I was waiting to hear thx you. I believe the reason why my egr throws a code is becuase the person who did my h22 accord swap forgot to swtich the a6 and a11 pins on the ECU.
Old 05-26-2006, 11:31 AM
bb4socal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">I believe the reason why my egr throws a code is becuase the person who did my h22 accord swap forgot to swtich the a6 and a11 pins on the ECU.</TD></TR></TABLE>
Help me understadn this?? Im having egr issues also. Why would you need to switch the a6 and a11 pins?? a6 is "HO2S Heater Coil". How in any way does this relate to the a11 (EGR Contro Solenoid)?? I did a h23 to h22 swap in my 4th gen, using h23 wire harness, would i have to also switch these pins around?? I just would like to get my EGR working again. And i cant figure out why it doesnt work.
Old 05-26-2006, 11:41 AM
On the accord A pin 6 and A pin 11 are the EGR solenoid and o2 sensor heater wire on the accord, but on the prelude it the opposite. So if you doing the h22 swap in to the accord you need to swap these pins. So A pin 6 goes where 11 was and so forth. This is necessary for the EGR solenoid to work which in return makes you EGR work I believe, they work together. I got this info form a h22 to accord swap article. Not sure about the h23 swap though.
Old 05-27-2006, 12:27 PM
Anyone know a good method of cleaning the EGR valve.
Old 05-27-2006, 01:13 PM
b*saint's Avatar
A code is just the result of something else that is malfunctioning. The code is not the problem. EGR is just a solenoid that recirulates exhaust gas to "waterdown" the intake air with Nitrogen or something. I say don't bother. If its plugged then great.
Old 05-27-2006, 02:51 PM
As far as I know if I'm getting a code 12 for the EGR then I have to target just that. What your saying makes some sense to some degree, but I still want this problem resolved.
Old 05-27-2006, 07:35 PM
Qveon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know if I'm getting a code 12 for the EGR then I have to target just that. What your saying makes some sense to some degree, but I still want this problem resolved.</TD></TR></TABLE>
Do you get a code 12 when it is all hooked up normally? If so then it is possible your EGR solenoid is not operating. That stops vacuum from going to the EGR valve which will not lift it giving you that CEL.
If you want to check and see if your EGR valve is bad, start the car and hook a vacuum line from the intake right to the EGR and see if it kills the engine. If so your solenoid is probably bad or the wiring is messed up.
Old 05-27-2006, 10:18 PM
Altilude's Avatar
Default Re: (Qveon)
qveon the egr guy (; haha
yea or do this https://honda-tech.com/zero...age=2
(another qveon tip)... if you just want to rid yourself of egr probs all together - still works for me!
Old 05-28-2006, 05:24 AM
Interesting I'll try that and post the results thx dude.
Old 05-28-2006, 06:43 AM
Qveon's Avatar
Default Re: (Altilude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altilude &raquo;</TD></TR><TR><TD CLASS="quote">qveon the egr guy (; haha</TD></TR></TABLE>
I'm just an EFI bitch in general
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know a good method of cleaning the EGR valve.</TD></TR></TABLE>
This seems to work:
Old 05-28-2006, 11:48 AM
It seemsas in this pic that you have the EGR holes plugged off right?
Old 05-28-2006, 09:46 PM
ilikehonda's Avatar
the egr valve will not open untill the car is completly warmed up
pclouthier
Honda Civic (2001 - 2005)
07-06-2014 03:01 AM
K-Spec
08-26-2006 11:04 AM
.BigSexy
06-18-2006 10:04 PM
kb58
11-06-2003 12:29 PM
y2ks2k
07-26-2003 05:56 PM
Quick Reply: EGR valve question
