code 9/keyless entry prob/stock radio
Guest
Posts: n/a
did alot of search with the code 9, not really any help besides replace the dizzy. any one else have any insight?
keyless entry and radio prob- could the problems be connected. i also did a search and people just said to get a new one or its fried. im a stero noob so how can i tell if its fried. and somelse metioned to check the internal supply fuse. how do u take off radio casing? the radio worked at the morning on the way to school but on the way back it didnt turn on?
Re: code 9/keyless entry prob/stock radio (john d)
you must not have searched hard enough. Ive answered at least 4 of these code 9 threads. Gotta meter the 2 and 4 on the dizzy connector. then meter it at the ECU female connector. No reading or reading from one side to ground = dead CYP sensor = new dizzy HOUSING, not entire dizzy.
Guest
Posts: n/a
Re: code 9/keyless entry prob/stock radio (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">you must not have searched hard enough. Ive answered at least 4 of these code 9 threads. Gotta meter the 2 and 4 on the dizzy connector. then meter it at the ECU female connector. No reading or reading from one side to ground = dead CYP sensor = new dizzy HOUSING, not entire dizzy.</TD></TR></TABLE>
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">need me to explain more in detail ? pics of where or how? what ohms they need to read at? </TD></TR></TABLE>
itd be greatly appriciated
Modified by john d at 2:29 PM 10/26/2004
You need to dissconnect the dizzy, then pull the top half (the male side) of its rubber mount to check these 2 connectors. Get a Meter and set it on ohms ( the omega sign) It needs to read between 260 - 460 ohms. Also, check it from one connector at a time, to a ground source on the body. If it has a reading to a ground source, that means its shorted. If you dont get a reading or it is shorted, you need to replace the dizzy ignition housing.
Next, pull the ECU out, and disconnect this connector.
Meter these 2 spots. Again, you need to read between 260-460 ohms. Again check it to a ground and see if you get a reading. If you get nothing, you have an open in the wire somewhere from the dizzy back in the harness.
I didnt have my keys in the ignition or anything when i checked this stuff on my car. You may have to put your keys in a turn it 1 click to get a reading on the connector at the ECU. Good luck.
If all else fails pull the cap off and if you got red dust and **** in your dizzy, your ignitor is gone.
<U>And someone FAQ this ****!!!!</U>
Guest
Posts: n/a
<U>And someone FAQ this ****!!!!</U></TD></TR></TABLE>
STICKY
STICKY
Guest
Posts: n/a
Re: code 9/keyless entry prob/stock radio (v-technician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-technician »</TD></TR><TR><TD CLASS="quote">what is the problem with the keyless and the radio, please explain......</TD></TR></TABLE>
basicly they dont work
raido- it doesnt turn on or anything. but the clock and the lil anti theft light flashes
keyless entry- doesnt do a thing when i press unlock/lock on my remote.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d »</TD></TR><TR><TD CLASS="quote">
keyless entry- doesnt do a thing when i press unlock/lock on my remote.</TD></TR></TABLE>
ramstrung
09-16-2007 04:45 PM
