Can I use an H23 distributer on a H22?
I will be swapping my h23 from my 92 Prelude Si with a jdm h22a. Can I use the h23 distributer and external coil in place of the h22 distributer with internal coil? This would allow me to use the h23 engine harness and a Rywire harness for the balance. Thanks in advance.
I have searched - some say yes and some have done the wiring conversion to use the h22a distributer. I would like more input please.
Re: Can I use an H23 distributer on a H22? (logicdc)
Yes keep the H23 dizzy and harness. Thish way all you have to wire up is the vtec sol and pressure switch. Add a p13 and your good to go
Re: Can I use an H23 distributer on a H22? (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">Yes keep the H23 dizzy and harness. Thish way all you have to wire up is the vtec sol and pressure switch. Add a p13 and your good to go </TD></TR></TABLE>
EDIT: Mis-read year.
Re: Can I use an H23 distributer on a H22? (slamdlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdlude »</TD></TR><TR><TD CLASS="quote">That is exactly what i did when I did my swap. Used the Rywire harness also. </TD></TR></TABLE>
So the dist lined up properly and looks stock??? I realize I will have to find a place for the coil but I want to make sure the dist is legit in case I ever sell the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logicdc »</TD></TR><TR><TD CLASS="quote">
So the dist lined up properly and looks stock??? I realize I will have to find a place for the coil but I want to make sure the dist is legit in case I ever sell the car.</TD></TR></TABLE>
Yes it will line up. You can use all 3 bolts and not cut off the ears like a crapy b series old school swap lol
deathbus
10-13-2010 10:30 PM
