build time : h23 block and h22 block differences
ok after spending about and hour and a half reading in the archives i didn't really find my answer. Its time for me to build my motor. thing is i can't take it out of the car so i was going to buy another block bare and have it send out and sleved and build the block outside of the car
thing is h22a1 blocks are so hard hard to find, and h23a1 are all over the palce,
my question is if i buy a h23 block and sleve it and build it and swap my crank and new rods and pistons in and put on the h22 head will it be just like having a built h22 block
i guess im asking is what are the difference between the h22a1 and h23a1 bare block with nothin in it (not even the oil squirters) ?
Re: build time : h23 block and h22 block differences (Boosted97Lude)
Right, the H23 and H22 blocks are from the exact same mold. The H23 didn't come with the oil squirters but they can be intalled.
Re: build time : h23 block and h22 block differences (JDM LUDE)
i just wanted to know so if i buy ah23 if i can ge it sleved and move ALL my h22 stuff over, i don't want an h23 vtec at this point in time, im going turbo.
Re: build time : h23 block and h22 block differences (H22Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Si »</TD></TR><TR><TD CLASS="quote">Right, the H23 and H22 blocks are from the exact same mold. The H23 didn't come with the oil squirters but they can be intalled.</TD></TR></TABLE>
i wish i would have know that, i would have had my h23 block sleeved instead of selling it for $100
Re: build time : h23 block and h22 block differences (mycro_machine)
Correct, although the piston oil jets will get in the way of the H23 crank, just carefully bend them out of the way.
Also in the h23 block there is an oil orifice or something in the top of the block that the h22 does not have but i dont think it will cause any issues.Also make sure you use the head gasket for the h22.
Re: build time : h23 block and h22 block differences (str8rcn)
hmm i don't see the difference maybe i didn't look clsoe enough
h23a1
h22a1
anyone else see it? , oh and by the way anyone else have a better top shot of an h23a1 ? post it thanks
h23a1
h22a1
Re: build time : h23 block and h22 block differences (prelittlelude)
What i was talking about is in the upper right hand corner near the water pump.I have a h23 head an a h22a block,dont ask why all i could get at the time,and yes everything is identical but in that corner it leaked using an h22 head gasket but was fine with the h23 head gasket.Everything else lined up fine.Maybe its because i have an h22a block and not h22a1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8rcn »</TD></TR><TR><TD CLASS="quote">.Maybe its because i have an h22a block and not h22a1.</TD></TR></TABLE>whats the difference between the h22a and the h22a1?
Re: build time : h23 block and h22 block differences (92'legend)
do u want to know the exact differences? , do you mean between the bare blocks, or do you mean whats the difference between a complete h22a1 and h22a?
my guess is differecne between bare blocks, nothing but the stamp, and difference between the complete engines, i think compression intake mani, cams, could be wrong though
bare, block, blocks, build, difference, differences, diffrences, f20c, g, h22, h22h23, h23, series, swap, time
