Misfire at idle
Old 10-25-2013, 01:04 PM
Ephosay's Avatar
Default Misfire at idle
How should I go about diagnosing this?
I pulled the codes myself and got a cylinder 1,3,4 misfire
I've changed my spark plugs, wires, valve cover gasket, and sparkplug seals.
Also the CEL blinks when idle sometimes and stops flashing when the car is above 2000rpms
This is what my exhaust sounds like
Old 10-25-2013, 07:23 PM
David77's Avatar
Default Re: Misfire at idle
Have you run a compression test? Because that sure sounds like a connecting rod slap to me.
Old 10-25-2013, 09:41 PM
motoxxxman's Avatar
are the wires on the distributor cap correctly?
do a valve lash adjustment?
compression test?
check timing belt?
fuel injector wiring?
Old 10-25-2013, 10:34 PM
Ephosay's Avatar
compression test?
check timing belt?
the wires are secure, I havent been able to get a compression test yet but im going to get that done asap
also, i forgot to mention that in the lower rpms, when i start adding a bit of gas i can feel the car slowly speed up in surges. doesnt feel smooth as its supposed to
Old 10-26-2013, 11:40 PM
holmesnmanny's Avatar
It always cracks me up when someone says the CEL light blinks but then proceeds to wonder how to find out what the problem is.
I guess to some people when the CEL blinks it does that just for the hell of it. It has nothing to do with their problem(s).
Old 10-27-2013, 03:45 AM
Ephosay's Avatar
If your saying I didn't pull the codes.. I did.. I have random misfires in cylinders 1,3, and 4.
Old 10-27-2013, 06:04 AM
motoxxxman's Avatar
I didn't mean are the wires on the cap securely, I meant are the wires on the cap in the correct locations?? people often put them on in the wrong locations which causes multiple cyls to not fire.
Old 10-28-2013, 09:08 AM
Moderator
crazes's Avatar
wtf, misfire is the least of your problems. you need to do a compression test asap. that sounds like valves slapping.
Old 10-28-2013, 07:29 PM
Ephosay's Avatar
Got the compression test done and my numbers are
#1 195
#2 183
#3 38
#4 200
Third cylinder wet compression test got 50. Could it be I have a burnt valve?
Old 10-28-2013, 07:34 PM
Ephosay's Avatar
Yeah I made sure they are on the right spot. Could my misfire be coming from my valves?
Old 10-28-2013, 07:41 PM
zanklc's Avatar
my guess would be something to do with that 3rd cylinder probaly bad rings or a cracked piston my friend had that on a d series did the same thing but if it was me id pull the motor and replace the block there usually cheaper then buying pistons and the machine work and rod bearings and all that stuff you dont wanna have to do but the low compression would feel like amisfire and a loss in power
Old 11-16-2013, 04:45 AM
TuyenEK's Avatar
yep what he said^^^^
daboy155
33
05-28-2018 01:39 PM
CLCrandall
Honda CR-V & Element
16
12-13-2016 11:50 AM
egvr4
01-28-2013 07:41 AM
FBPPrelude
12-27-2006 07:12 PM
JFG Kevin
07-17-2006 12:20 PM
Quick Reply: Misfire at idle
