What type of oil do you use in your yamaha
Old 01-13-2007, 04:12 PM
.Kevin.'s Avatar
Default What type of oil do you use in your yamaha
I was going to change my oil in my yzf600r but have read so many mixed reviews on oil. I went to the store today and saw castrol syntec blend oil for $3.28 a qt. for 10w-40. Now is this oil ok to run in the bike?
Old 01-13-2007, 04:32 PM
Honda-Tech Gold Member
ScareyH22A's Avatar
Default Re: What type of oil do you use in your yamaha (Ep_Kevin)
high mileage should stay away from synthetics.. blends i don't know too much about.
Just use Yamalube
Old 01-13-2007, 05:00 PM
The_Head's Avatar
Default Re: What type of oil do you use in your yamaha (ScareyH22A)
I use Yamalube in mine, but I have used the Honda brand of motorcycle oil when the stealership I used to go to never kept Yamalube in stock.
I use 10W-30 in spring/fall and 20W-40 in the summa.
Old 01-13-2007, 05:17 PM
Khmai_guy's Avatar
Default Re: What type of oil do you use in your yamaha (The_Head)
I use motul 5100 10-40 weight on my 05 R1.
Old 01-13-2007, 10:14 PM
marmaladedad's Avatar
Do NOT put Honda oil in your Yamaha! The oil is NOT compatible, and your bike WILL self-destruct.
As long as the oil label does not say "Energy Conserving" on the little round label on the back, it's safe to use for motorcycles. You don't need to buy motorcycle-specific oil.
I had Honda GN4 (dino / non-synth) in the Superhawk, Motul 5100 (semi-synth...right? I don't remember anymore) in the GSXR750, and Motul 5100 in the KTM.
Old 01-13-2007, 10:16 PM
Johnny_Rocket's Avatar
Default Re: (marmaladeboy)
Spectro Gold
Old 01-14-2007, 08:59 AM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">Do NOT put Honda oil in your Yamaha! The oil is NOT compatible, and your bike WILL self-destruct.
I had Honda GN4 (dino / non-synth) in the Superhawk, Motul 5100 (semi-synth...right? I don't remember anymore) in the GSXR750, and Motul 5100 in the KTM.</TD></TR></TABLE>
Yes I have read about the energy conserving stuff in the oil and it seems once you pass a 30 weight they do not use it. I though was wondering if 10w-40 was ok to use. The manual says that you should use 10-30 or 20-50 I think? I also read that since it lubes the trans also a higher weight was reccomended.
Old 01-14-2007, 10:23 AM
The_Head's Avatar
Default Re: (Ep_Kevin)
A few years ago I used Castrol GTX in my Bandit 1200, never had a problem with it.
Old 01-14-2007, 10:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep_Kevin &raquo;</TD></TR><TR><TD CLASS="quote">Yes I have read about the energy conserving stuff in the oil and it seems once you pass a 30 weight they do not use it. I though was wondering if 10w-40 was ok to use. The manual says that you should use 10-30 or 20-50 I think? I also read that since it lubes the trans also a higher weight was reccomended. </TD></TR></TABLE>
Ah, I didn't know that about the 30wt-and-up thing. Interesting.
I tried using both 10w40 and 20w50 in my Superhawk, and didn't notice a huge difference. I want to say the shifting felt smoother when I put the 20w50 in, but that was most likely a psychological effect.
Old 01-14-2007, 01:47 PM
Kyles ej1's Avatar
mobil 1, $10 a qt
Old 01-14-2007, 01:57 PM
.Kevin.'s Avatar
Default Re: (Kyles ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 &raquo;</TD></TR><TR><TD CLASS="quote">mobil 1, $10 a qt </TD></TR></TABLE>
Old 01-14-2007, 02:00 PM
.Kevin.'s Avatar
There is no way I am paying 10$ a qt. for mobil one specifically for motorcycles. I bite the bullet at 6$ or something a qt for my car.
I think I am going to get the synthetic blend. I did some research and I have come to see that mobil sued penzoil and another company for using type III oil and calling it synthetic so mobil started to do that once they lost their case and called it mobil 1 synthetic. So actually no motor oil is truelly synthetic.. Actually I do think I read that there are four manufactures that produce pure synthetic oil.
Old 01-14-2007, 02:06 PM
The_Head's Avatar
I really don't think it matters much what you use as long as you change the oil and filter regularly.
Old 03-04-2007, 07:46 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep_Kevin &raquo;</TD></TR><TR><TD CLASS="quote">There is no way I am paying 10$ a qt. for mobil one specifically for motorcycles. I bite the bullet at 6$ or something a qt for my car.
I think I am going to get the synthetic blend. I did some research and I have come to see that mobil sued penzoil and another company for using type III oil and calling it synthetic so mobil started to do that once they lost their case and called it mobil 1 synthetic. So actually no motor oil is truelly synthetic.. Actually I do think I read that there are four manufactures that produce pure synthetic oil.</TD></TR></TABLE>
mobil 1 is still mostly synthetic. they use a group IV/V basestock for M1, but dissolve the additive package in a group III. technically it's not a full synthetic because of that, but it's good enough for me...
iirc, royal purple, motul, amsoil, redline, german castrol are all full syn's, but generally hard to find and goddamned expensive.
what angers is me is how much Bert's charges for quarts of HP4
Old 03-04-2007, 08:13 PM
85's Avatar
Default Re: (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">A few years ago I used Castrol GTX in my Bandit 1200, never had a problem with it.</TD></TR></TABLE>
I emailed a few oil companies and asked what the REAL difference is between motorcycle and car oil. basically there is a extra thing in the car oil. (can't remember what its called.) that helps to make it super slick to improve gas mileage but isn't found in all oil. the oil companies said that at worst, it can cause the clutch to slip. ive tried car oil in all of my bike and the only problem ive ever run into was it making my 02' GSXR 750 (which had a clutch that was pretty worn anyway) start slipping. all i did was drain the oil and put motorcycle oil back in without flushing or changing the filter and it was back to normal.
Old 03-04-2007, 08:52 PM
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
what angers is me is how much Bert's charges for quarts of HP4 </TD></TR></TABLE>
HP4 is Honda's Synth, right? I bought mine from here:
http://www.hondadirectlineusa....09111
Old 03-04-2007, 09:54 PM
trbo823's Avatar
I use Motul.
Old 03-05-2007, 06:56 AM
Jasper_db1's Avatar
I use Shell Rotella T 5W-40 Synthetic in my 600r
Old 03-05-2007, 07:07 PM
bustdesenuts's Avatar
Default Re: What type of oil do you use in your yamaha (Jasper_db1)
i used motul 5100 15w50 on my r6. nothing but the best!
svhiker
08-04-2017 03:19 PM
gooblinn258
05-12-2014 10:54 AM
danteisme
Honda Motorcycles
04-01-2008 09:45 PM
playahwitgame
Honda Motorcycles
03-13-2007 08:06 PM
honhatchisbak
Honda Motorcycles
24
09-17-2004 02:46 PM
Quick Reply: What type of oil do you use in your yamaha
