Bleeding the clutch on an 84 nighthawk 650
Old 08-14-2008, 11:35 AM
89sparks's Avatar
Default Bleeding the clutch on an 84 nighthawk 650
Alright, I'm pretty new to motorcycles and I have a hydraulic clutch on my cb650sc. I drove it for the first few days when I bought it and the clutch felt fine but like I said, I'm new to the game so it may not have been right. But i noticed one night that the clutch will sometimes not fully free when the clutch handle is held in all the way so I checked the fluid and sure enough it was basically empty. I filled the resevoir but I know I need to bleed the lines.
Can anyone help me with how this is done? I know how to bleed A clutch, I just need to know how to bleed THIS clutch. Thanks.
Old 08-14-2008, 11:46 AM
My Name is Nobody
MSchu's Avatar
Default Re: Bleeding the clutch on an 84 nighthawk 650 (89sparks)
Its the same as any other hydraulic system...
pump the lever until you build pressure, hold the lever, unscrew the bleed screw, release the air in the system, tighten the bleed screw, release the lever...
Do this a few times (At least twice) until you have good pressure and function at the lever
Old 08-14-2008, 11:48 AM
89sparks's Avatar
Thanks for the reply, but I don't know where the clutch fluid line goes to. I'm trying to follow it but I lose it underneath the gas tank
I know I'm a newb
Old 08-14-2008, 12:19 PM
My Name is Nobody
MSchu's Avatar
Default Re: (89sparks)
More than likely on your bike it is down by the clutch(I don't know your bikes layout specifically)... look for a bleed screw, that really is the only thing it could be by the clutch and a bleed screw
Are you sure the 84 nighthawk has a hydraulic clutch? I know some guys on here have owned that bike
Old 08-14-2008, 12:25 PM
89sparks's Avatar
Positive that my bike has a hydraulic clutch. I know my buddies 85 nighthawk 450 is a cable clutch and chain driven. My 84 nighthawk 650 is a hydraulic clutch and driveshaft driven
Old 08-14-2008, 01:11 PM
iLude's Avatar
Yeah, its hydraulic.
I've done this too... but I can't remember. Just follow the line down and you'll hit the bleeder for it, its right in front of the clutch itself IIRC. Other than that, it's pretty straight forward. Took me like 10 minutes to do.
Old 03-27-2020, 03:15 PM
B t
B t's Avatar
I can't seem to get the fluid to flow through the bleeder valve no matter how many times I pump it up
Old 03-27-2020, 03:18 PM
B t
B t's Avatar
The clutch master cylinder will not pump up I don't know what to do
Old 04-08-2020, 08:28 AM
HeLLyeaSon's Avatar
where you able to find the clutch line bleeder? if so try using mighty vac brake line bleeder to remove air from clutch line
Old 05-24-2020, 05:27 AM
shoulet's Avatar
Clutch actuator is on the left side, take the bleeder screw right out and then teflon tape it or else it won’t seal. Have you nothing any leaks coming from the actuator? i had to fix mine last year.
diviznrider
02-04-2011 11:01 AM
sTohc99
04-15-2006 08:01 PM
Bserieskiller
02-17-2006 05:52 PM
Simple
09-17-2004 11:16 PM
stRtypR25
01-22-2003 08:34 PM
Quick Reply: Bleeding the clutch on an 84 nighthawk 650
