Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 Honda CR-V headlight harness plug problem
Old 09-03-2013, 06:16 PM
TSteidel's Avatar
Default 2005 Honda CR-V headlight harness plug problem
I recently experienced a left headlight failure. Upon investigation, I found that the H-1 bulb was burned out (easy replacement) but, what's worse, the plug in the wiring harness had worked loose, and apparently arced/overheated, causing the plastic plug to partially melt. I've cleaned up what remains of the two-prong harness plug, and the mating two-prong socket, so the light works again...for now. Does Honda sell the wiring harness plug, or do I have to resort to a junkyard to find a used plug from a wreck, in order to provide a more permanent and reliable "fix?"
GrimLude
05-13-2014 11:24 AM
Pancho2193
11-24-2012 10:02 PM
bdubnyc
02-10-2008 03:27 PM
Wazup
05-06-2003 10:03 PM
Quick Reply: 2005 Honda CR-V headlight harness plug problem
