Honda CR-V & Element 2WD & 4WD Element & CR-V
1999 CRV shifting problem
Old 10-13-2011, 11:57 AM
kittycars's Avatar
Icon2 1999 CRV shifting problem
We are replacing a timing belt on our 1999 CRV and have taken the cylinder head off to check the valves. We have tried to shift it into neutral but the gear shift won't move. The key is in the accessory position. Any ideas? Thanks
Old 10-13-2011, 03:59 PM
qwrty's Avatar
Default Re: 1999 CRV shifting problem
have you tried it in ignition position and pressed the brake pedal??
Old 10-13-2011, 04:35 PM
kittycars's Avatar
Yes, we tried that. We are going to try the brake switch tomorrow and see if it is defective. I have read about a shift lock system that says you can override it by inserting a key into the release slot in the upper steering column cover but I don't see it on this car. Hopefully, I won't need to. I'll post how well it goes tomorrow. Thanks for your input.
Old 10-13-2011, 04:36 PM
ARMED's Avatar
what he said.......ignition position
Old 10-15-2011, 10:53 AM
kittycars's Avatar
The shift lock solenoid tested fine. The key is in the ignition position and it still won't shift. We do have the front of the car on jack stands and a jack under the oil pan. Could this be a problem? the shift cable doesn't seem to be in a bind. Thanks for any input.
Old 10-15-2011, 01:20 PM
qwrty's Avatar
did you try pressing the brake pedal???
try putting back the batter may be theres an electrical contacts that needs to shifts it..
try playing around w/ it may be the key position is loose...
g/l!
Old 10-16-2011, 12:10 AM
The Chazzer's Avatar
You said you put the key into the "ACC" position. Go one more click to "ON". I bet it works.
Old 10-16-2011, 11:05 AM
Aliman's Avatar
gotta have the battery conected up guys that issh works with electricity
JZiggy
10-08-2014 03:54 PM
idewson
11-22-2007 11:37 AM
yellowdcn
02-28-2005 01:06 PM
tFUnK
05-04-2002 06:18 AM
Quick Reply: 1999 CRV shifting problem
