Honda CR-V & Element 2WD & 4WD Element & CR-V
2nd gen lift spacers
Old 01-07-2017, 08:21 AM
ohm13's Avatar
Default 2nd gen lift spacers
has anyone tried these? any idea why fronts are 20mm and rears 40mm? I know some people have made their own, if you have I would love some specs. Thanks
http://www.ebay.com/itm/Front-strut-spacers-for-Honda-ACURA-RSX-CIVIC-CRV-ELEMENT-INTEGRA-20mm/112105929771?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40778%26meid%3D54158b55bfca4f72a10c916b249c74b4%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D112110457486
http://www.ebay.com/itm/Rear-strut-spacers-for-Honda-CRV-CIVIC-CROSSROAD-ELEMENT-40mm/112116988193?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40778%26meid%3D54158b55bfca4f72a10c916b249c74b4%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D112110457486
Old 01-07-2017, 08:26 AM
-Intl Steve Krew
Caoboy's Avatar
Default Re: 2nd gen lift spacers
Look at your CR-V.
The rear is lower than the front.
20mm is about .75 inch.
40mm is 1.5 inch.
​​​​​​Using these two measurements will give the CR-V an 'even' lift of about 1", getting rid of the rearward rake.
That being said, if you buy OME springs for the CR-V it will raise the rear 3/4" as well, leaving the front at stock height. The whole vehicle will look taller though, because the rake has been removed.
Old 01-09-2017, 08:48 AM
acmoc's Avatar
I always wondered if the rear was really lower than the front.I thought it was just the body lines.
Old 01-09-2017, 03:35 PM
-Intl Steve Krew
Caoboy's Avatar
it might be.
Lift your mom's CR-V sup
edelwolf
Honda Civic (2001 - 2005)
11
06-12-2014 03:35 PM
buell22
01-23-2008 09:08 PM
Kato7997
02-24-2003 10:03 PM
lonefuzzy79
24
10-02-2002 10:37 AM
Quick Reply: 2nd gen lift spacers
