Honda CR-V & Element 2WD & 4WD Element & CR-V
2001 CR-V 5 Speed VSS Location
Old 05-02-2013, 04:29 PM
amoeller's Avatar
Icon2 2001 CR-V 5 Speed VSS Location
A few days ago my speedometer stopped working and the check engine light came on. I have a code reader and got a P0500 code and from what I've found its an issue with the vehicle speed sensor (VSS). I found a few locations on the car that look similar to the VSS but I'm not 100% sure. The wires at least I thought were the VSS connectors I cleaned out with electrical contact cleaner. That worked for a day so now its back to not working again. Whenever I clean the connectors out the speedometer works but only for less than a day. Can someone tell me where the VSS is exactly on a manual 2001 CR-V? A photo would be much appreciated. At least right now I think there is an issue with ether the wiring or the VSS it self, so I would have to replace the VSS.
Thanks in advance.
Old 05-02-2013, 08:09 PM
Retired Moderator
EsotericImage's Avatar
Default Re: 2001 CR-V 5 Speed VSS Location
VSS is on trans case under throttle.
Tank_EM2
Honda Civic (2001 - 2005)
07-01-2014 03:28 PM
lame05
05-13-2013 07:41 AM
civicSF98
10
08-30-2009 05:10 PM
aziaticvang
01-13-2008 06:35 PM
turismo128
09-27-2005 03:22 PM
Quick Reply: 2001 CR-V 5 Speed VSS Location
