2005 CRV - Power Door Lock switch
Hi Everyone,
The power door lock switch on my driver's side door doesn't unlock the door when I push up on it. I googled the problem and replaced the drivers side door lock actuator, but the problem still exists. The remote key fob works fine, the key in the cylinder locks/unlocks the car fine, and the power door lock switch locks the car just fine when I press down on it. All fuses are also ok. Only the power door lock switch doesn't unlock when I press up on it.
Anyone else experience this? Any ideas?
I tested the power door lock switch from the passenger side on the driver's side plug, same issue, so I don't think it is the switch itself. That's why I thought it was the driver's door lock actuator, but a new one hasn't solved it.
Am I down to an electrical/wiring issue? Or is there a problem with the complete door lock assembly, not just the actuator?
Really annoying and want to fix it without having to go to the stealership...............Canadian CR-V here with 230km and going strong
Thanks for any info. or help!
lrhtech
07-13-2015 05:30 PM
bdoberst
01-07-2015 11:55 AM
MIBPreacher
Honda Civic (2001 - 2005)
02-03-2013 04:38 PM
