Honda CR-V & Element 2WD & 4WD Element & CR-V
Are the 1st gen. radiator fans the same left & right ?
Old 01-12-2014, 02:01 PM
blk1stgen's Avatar
Default Are the 1st gen. radiator fans the same left & right ?
I need to k now if the left and right fan assemblies are the same , i need to replace the radiator on my CR-V but the previous owner used a universal style of fan assembly that pierces through the radiator and i dont want to do that , i want to replace it correctly .
I found a left side radiator fan but i cannot find the right , i am assuming they are both the same but i have not found any info on it . \
Thanks !
Old 01-12-2014, 02:06 PM
ap1jnky's Avatar
Default Re: Are the 1st gen. radiator fans the same left & right ?
Just replaced my radiator this weekend The mounting points on the fans are not the same. Driver side has two bolt's that line up ontop and a stop at the bottom passenger side has two bolt's on top also but they sit flush with the radiator and not flat ontop like driver side and also has two more bolt's at the bottom. You can rig it im sure of it but prob wouldn't look clean.
Old 01-12-2014, 02:16 PM
ap1jnky's Avatar
Found these on ebay for around $40
Driver's side
Passenger side
Old 01-12-2014, 02:30 PM
blk1stgen's Avatar
Driver's side
Passenger side
awesome thanks!
so left & right are different then?
Old 01-12-2014, 02:34 PM
ap1jnky's Avatar
No problem and yes mounting points are different
Old 01-12-2014, 03:55 PM
ARMED's Avatar
yes different
Old 01-12-2014, 04:38 PM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
I could be wrong but I am pretty sure the electrical connections are different as well. Either way the mounting brackets are different for sure.
Old 01-15-2014, 03:56 PM
blk1stgen's Avatar
woot! found one at Napa for $88 brand new , replaced leaking radiator & all is good now
Old 01-15-2014, 06:31 PM
ap1jnky's Avatar
Radiator? Got mine off ebay for $58 shipped called my napa they wanted $118
Old 01-16-2014, 03:05 PM
blk1stgen's Avatar
no, i found the fan assembly at napa, i bought my radiator from a Denso parts distributor for $60 with tax .
All went in smooth as silk & i have taken it on a 150 mile road trip w/o problem
Old 01-16-2014, 04:38 PM
ap1jnky's Avatar
Good Lord.. well glad it worked out for ya
eightvalver
09-22-2007 01:17 PM
HTn00b
11-27-2006 08:06 AM
Herbie
11-06-2006 02:38 PM
4doorH22
01-19-2002 12:12 PM
not so civic
07-05-2001 07:45 AM
Quick Reply: Are the 1st gen. radiator fans the same left & right ?
