Zc Head Swap???
Old 09-04-2005, 01:30 AM
HondaHemi's Avatar
Default Zc Head Swap???
Can you swap like a D-series VTEC head or something onto a SOHC Zc??? or maybe the DOHC D16a1, or DOHC Zc head onto a SOHC Zc???? I was just wondering cause i thought the Zc was just a japanese D series
Old 09-04-2005, 05:27 AM
SomeDude56's Avatar
Default Re: Zc Head Swap??? (HondaHemi)
stick to hemis........................or search.. i bet i can find one out in the forum right now to answer that........wait.........yea i did
Old 09-04-2005, 09:26 AM
dr_latino999's Avatar
Default Re: Zc Head Swap??? (SomeDude56)
Damn newb, you can be nice and answer
Assuming all head swaps are going to a D16A6 block
DOHC ZC - Headbolt pattern is different, will not work.
SOHC ZC - Same head as the D16A6, bolt-on replacement
D15B - Same head as the D16Z6, bolt-on replacement
Old 09-04-2005, 11:12 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHemi &raquo;</TD></TR><TR><TD CLASS="quote">Can you swap like a D-series VTEC head or something onto a SOHC Zc??? or maybe the DOHC D16a1, or DOHC Zc head onto a SOHC Zc???? I was just wondering cause i thought the Zc was just a japanese D series</TD></TR></TABLE>
The last part of your statement is true, but the usdm and jdm engines don't really have any physical differences which would prohibit a head swap. All d-series sohc engines should be able to swap heads. I don't really see why you would want to, unless you have one head and one block sitting around or something. DOHC ZC head will NOT go onto a SOHC block. It is possible, but with alot of welding and probably duct tape. Basically just don't do that.
p.s. the d16a1 doesn't bolt directly into any civic, and I don't believe mount kits are made for it.
89hbcivicguy
08-09-2005 06:04 PM
jdmspeck
01-04-2005 08:46 AM
Si_Power
07-12-2003 10:15 PM
SecretMan
03-06-2003 05:20 PM
Quick Reply: Zc Head Swap???
