Windshield Wiper help
Old 11-26-2010, 03:26 PM
91efbluehatch's Avatar
Default Windshield Wiper help
having a problem with my driver side wiper.
replaces the bushings on the wiper linkage, but for some reason the wiper SLIDES off my windshield at around 30 mph. i have tried adjusting it, but it keeps happeneing.
is it the teeth on the assembly that you bolt it too??
need some help please and thank you.
Old 11-26-2010, 10:28 PM
hatchet_honda's Avatar
Default Re: Windshield Wiper help
wiper goes too far off the windshield? try removing it the repositoning the arm. orr are you saying that driving the car and by wind the arm moves across the windshield?
Old 11-26-2010, 10:34 PM
it has just glided off in the past, but i used the CRX wiper assembly, the part where you bolt the wiper onto, and when used with rain , and speed it slides farther than it should when in use. it is messing up my paint. i dont know if the teeth on the wiper arm itself is worn, or if it is the teeth on the actuator.
Old 11-26-2010, 10:39 PM
can you move that wiper arm by hand? independently from the other arm? check either the nut on the top or like you say the splines on the gear or the arm itself. somethins not tight enough
Old 11-26-2010, 10:43 PM
i tighten them down, adjust the arm down and it still moves past the original stopping point.
let me put it this way, i had to rock a monowiper for 4 months until i had time to swap everything out.
i actually think it may be the arm itself with the worn splines.
Tyte-S
03-01-2014 06:59 AM
maldana
Suspension & Brakes
08-08-2011 09:00 AM
beanbag
Suspension & Brakes
02-11-2009 06:04 AM
HUBB
02-26-2006 02:18 PM
kyden
Suspension & Brakes
01-25-2006 10:56 PM
Quick Reply: Windshield Wiper help
