Weird scraping/grinding noise when turning right
Old 07-14-2010, 09:08 PM
90ED6LSV's Avatar
Default Weird scraping/grinding noise when turning right
It makes a noise that sounds like my brakes are scratching when i turn right and go over bumps. (driver side) It's mostly the bumps that make it do that. It will do it when going straight sometimes over bumps. But never turning left.
Wheel bearing? and ideas?
Old 07-14-2010, 09:35 PM
BiG ChOr!Zo's Avatar
Default Re: Weird scraping/grinding noise when turning right
does it get worse when extra weight is in the car...!!!
Old 07-14-2010, 09:42 PM
Catfish4748's Avatar
b
Old 07-15-2010, 05:11 AM
jlk16188's Avatar
check to make sure the metal dust shield on the brake isnt rubbing on the rotor. Ive seen them rusted so bad that it broke off and wedged itself between the rotor and the back of the caliper. Sounded like a freight train driving down the road
Old 07-15-2010, 09:56 AM
TJChad's Avatar
wheel bearing is starting to go. Look up a at a recent post about a loud noise...
Old 07-15-2010, 10:19 AM
91GEDHATCH's Avatar
I have the same thing. I'm assuming you have a ls swap from your name, if so, did you happen to change out an axle? I just did and forgot to take the o ring that sits up against the bearing off. I guess they don't fit the ef, just throwing it out there.
Old 07-15-2010, 10:36 AM
freight trains dont sound like that...its more like a stuck hand brake that someone forgot to take off
Old 07-15-2010, 02:26 PM
90efhatchic's Avatar
most likely a dust shield, does it sound metallic? wheel bearings will make a noise that picks up with speed and will do it straight on smooth roads doesnt need to turn or go over bumps to hear it... dust shields are common to get bent close enough to the rotor that turning and bumps will cause them to hit the road and grind but its sounds like thin pieces of metal not like if you where to take a grinder to a piece of rebar
Old 09-09-2011, 08:15 AM
90ED6LSV's Avatar
sorry never replied, it's the crank pulley grinding on the radius arm for the front subframe. it happens on big bumps and hard turns. I think it's because I had eBay mounts, mounted the engine too low, i have Hasport mounts in now and it hasn't done it again.
Old 08-29-2019, 08:14 PM
Saddest-Honda's Avatar
I've recently started noticing the same issue. I will sometimes hear a grinding noise when I turn left or right especially when I turn left, and sometimes when I hit a bump. I know what is making this noise and it is the brake rotor grinding on the radius arm. I do have the 87 acura integra brake rotors and calipers. I am aware that the 87 integra rotors are about 10 mm bigger than stock although I don't think that is part of the issue as I driven around with them for a while without any problems. I was wondering how to fix this issue, I was thinking if I adjust torsion bar nut to raise the ride height it might fix this. I have an 87 honda crx.
pnoipj89
07-24-2021 04:01 PM
Tigereye225
Honda Civic (2001 - 2005)
05-15-2016 03:59 PM
avio
04-16-2010 12:51 AM
vigorhy
03-20-2008 03:54 PM
coot_er
03-29-2005 03:47 AM
Quick Reply: Weird scraping/grinding noise when turning right
