Rebuilt Starter?
Old 05-27-2005, 10:29 AM
DaMmniTz's Avatar
Default Rebuilt Starter?
I believe my starter went out on me. I took it to a autozone store and tested it myself and it seems a little dry at 8 voltage. From the selonoid it seems dry. Is there any way to fix this? Cause it still works and all just takes a while to start the car up. I didn't want to pay 140 for a aftermarket starter at autozone. Oem is better...But if you can't rebuilt it, What motor would i get the starter off from? I'm running a sohc zc 1.6L single cam . Thanks.
Old 05-27-2005, 11:10 AM
DaMmniTz's Avatar
Default Re: Rebuilt Starter? (DaMmniTz)
is it cause i'm a noob? no help?
Old 05-27-2005, 11:32 AM
hatchinprogress's Avatar
you can use any d-series starter (depending on the year of you motor) if you got an obd-0 you can pull a starter from 88-91 civics/crx's i hope that answerd your question
Old 05-27-2005, 03:00 PM
vegaskurt's Avatar
Default Re: Rebuilt Starter? (hatchinprogress)
the auto starters are different, so avoid them.
Autozone carries two brands of starters, they have a $60 one that works great.
Old 05-27-2005, 05:48 PM
Kwicko's Avatar
Default Re: Rebuilt Starter? (vegaskurt)
What to you mean when you say it's "kinda dry"? And you say it *works*, but it just takes a long time. Do you mean you have to crank the car over for a long time before it catches and runs? If so, that's not your starter giving you trouble.
Depending on where you live, you can likely get your starter rebuilt locally for a whole lot less than buying a new/remanufactured one. I had mine go out on my '91 Accord; AutoZone wanted $171 for a reman. I got it professionally rebuilt locally for $70. Been working fine for three years now...
Mike
Old 05-28-2005, 12:45 AM
silentblackhat's Avatar
Default Re: Rebuilt Starter? (Kwicko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwicko &raquo;</TD></TR><TR><TD CLASS="quote">. Do you mean you have to crank the car over for a long time before it catches and runs? If so, that's not your starter giving you trouble.</TD></TR></TABLE>
maybe check timing, i read a few days ago thatif itsoff it couldd do that,
Old 05-28-2005, 09:40 AM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">you can use any d-series starter (depending on the year of you motor) if you got an obd-0 you can pull a starter from 88-91 civics/crx's i hope that answerd your question </TD></TR></TABLE>
So just to clear things up 92-95 D-series starters are diff. then 88-91 D-series starters?
Old 05-28-2005, 10:18 AM
Mach69's Avatar
Default Re: Rebuilt Starter? (JapJunkie)
I got a Pep Boys starter for like 70 bux. Been working fine for 2 years now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote">
So just to clear things up 92-95 D-series starters are diff. then 88-91 D-series starters?</TD></TR></TABLE>
I know '90-'95 D-series starters are practically identical. I am using my '90 STD starter on my d16z6 engine. Works like a champ. I am 95% sure that any '90 to '00 D-series manual transmission starters are interchangeable. As far as '88-'89 go, there might be an issue because the flywheel is smaller in those years. I am not sure about those.
Old 05-28-2005, 10:20 AM
JapJunkie's Avatar
Default Re: Rebuilt Starter? (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">I got a Pep Boys starter for like 70 bux. Been working fine for 2 years now.
I know '90-'95 D-series starters are practically identical. I am using my '90 STD starter on my d16z6 engine. Works like a champ. I am 95% sure that any '90 to '00 D-series manual transmission starters are interchangeable. As far as '88-'89 go, there might be an issue because the flywheel is smaller in those years. I am not sure about those.</TD></TR></TABLE>
Damn Im using my 89 Si tranny/flywheel on a D15b7...I forgot that the flywheel is smaller.... Now dont know wat starter to use...
Old 05-28-2005, 02:24 PM
Kwicko's Avatar
Damn Im using my 89 Si tranny/flywheel on a D15b7...I forgot that the flywheel is smaller.... Now dont know wat starter to use...</TD></TR></TABLE>
I think you'll be fine. As far as I know, the flywheels from '88 and '89 have the same OUTER dimensions as the '90 and '91s - it's the FRICTION SURFACE for the clutch disk, and possibly some of the dowels for mounting the pressure plate, that are different. I believe I used a '91 starter on my '89 D16A6 without any problems.
Mike
Old 05-28-2005, 02:35 PM
JapJunkie's Avatar
Mike</TD></TR></TABLE>
Well put, this is true, the dowels for mounthing the pressure plate are different.
That is why i ended up using my 89 Si clutch/flywheel instead of the B7 that came on the block. I just ended up choosing to go w/ the clutch and flywheel that came w/ the tranny.
Old 05-28-2005, 03:05 PM
DaMmniTz's Avatar
i went to pick n pull this morning and was looking for starters off 88-91 Civic/crx and integras. I unbolted a start from a 89 integra that on the outside looks the same but where the spindle spin, it has a half cut CONE on it? and my original one didn't. Would those fit? I didn't buy it yet.
Exactly What year of cars can i get it off of? Give me a few so i can look around. Stating one type of car and it's year isn't gonna help Junkyard doesn't have that much variety of honda. yup Thanks.
Old 05-28-2005, 03:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaMmniTz &raquo;</TD></TR><TR><TD CLASS="quote">i went to pick n pull this morning and was looking for starters off 88-91 Civic/crx and integras. I unbolted a start from a 89 integra that on the outside looks the same but where the spindle spin, it has a half cut CONE on it? and my original one didn't. Would those fit? I didn't buy it yet.
Exactly What year of cars can i get it off of? Give me a few so i can look around. Stating one type of car and it's year isn't gonna help Junkyard doesn't have that much variety of honda. yup Thanks.</TD></TR></TABLE> you cant use a teg starter because its b-series (grab a stater from a d-series motor)
Old 05-28-2005, 03:17 PM
DaMmniTz's Avatar
would it matter if it had that half cone protecting the spindle that spins at the end?
Cause the d 15 and some d16 starters i took out ALL had that cone....
Tim 59
Honda Civic (2006 - 2015)
09-01-2010 10:30 AM
crxaddikt
12
11-24-2008 06:47 PM
TiffanyJJ08
10-03-2005 12:35 PM
ghost_ryder35
03-19-2004 10:51 AM
Sukebei Oni
03-16-2003 01:21 AM
Quick Reply: Rebuilt Starter?
