CRX/Civic Si/Ex Front Suspension Questions
Old 08-01-2011, 06:18 PM
nightscream's Avatar
Icon2 CRX/Civic Si/Ex Front Suspension Questions
I forget how to tell EF Si/Ex front suspension from Dx junk.... I wanna say the Si/Ex has 32 splines & the Dx has 28 splines. Am I correct????? I buying an "Si/Ex" front suspension & I wanna make sure it is what he says it is! Catch my drift???
Old 08-01-2011, 06:36 PM
Tyson's Avatar
Default Re: CRX/Civic Si/Ex Front Suspension Questions
Si is not the same as EX (4dr).
EX is much bigger rotor. The knuckle is stamped differently... i forget exactly. perhaps SHA or something. i have pics in some other thread...
Si can be the same as DX. ONLY the 90-91 CRX, not 3dr civic Si, has a different front caliper, but the rotor and the knuckle is the same. otherwise, Si is the same as DX.
the HF has smaller rotor and caliper, the hub is smaller and has the different spline.
Old 08-01-2011, 06:43 PM
Good info & I know all of this... But I'm looking for the spline count on Ex/Si model front hubs...
Old 08-01-2011, 06:46 PM
Tyson's Avatar
the same as DX
Old 08-01-2011, 06:56 PM
POSITIVE!!!!???? Not trying to be a D*CK!!!!!!!!!! I could have swore there was a spline difference... Because I have a 98 GSR motor swap & a 11" 94-95 Legend front disc brake swap for my 88 CRX DX that will bolt on to my car with no issues at all...
Old 08-01-2011, 06:58 PM
Tyson's Avatar
GSR knuckle wont work on a EF.
it will "FIT", but it wont work. it will drive like crap.
Old 08-01-2011, 07:04 PM
Forget everything we have said....
Your saying an Ex/Si hub assembly / spindle is the same as a Dx hub assembly / spindle
AND THAT
my 94-95 Legend Dual piston caliper & bracket will bolt up on to my Dx hub assembly / spindle with no modding of any kind AND I'm just wasting my $$$$$$$$ buying a Ex/Si hub assembly / spindle
Old 08-01-2011, 07:07 PM
Tyson's Avatar
i AM saying, and HAVE SAID that EX is NOT the same as SI.
i will repeat for you.
do you understand? stop asking about "EX/Si".
finally, no that dual piston will NOT bolt up to your DX without some modifying a bracket or something. its detailed in some the "cheapest brake improvement" thread or something. basically its a lot of work and NOT bolt on.
Old 08-01-2011, 07:29 PM
I started this thread LOOKING for a SPLINE COUNT. I thought there were spline differences between the Dx & Si hubs & that was the easiest way to tell them apart!!!!! I know there are differences in Ex & Si brakes! If the splines are the same between the Dx & Si. How can I tell that they are Si front knuckles that will allow me to bolt on my Legend Front BRAKES???????????????????
We have been talking about 2 different things this entire time!!!!!!
Old 08-01-2011, 07:38 PM
Tyson's Avatar
they cant. so theres nothing to tell.
i know exactly what im talking about.
you, are confused. and the answer is NO, you cant use those brakes without modification.
and you probably need DA or EX knuckles since they need a bigger rotor too.
Old 08-01-2011, 07:42 PM
crx_si-r's Avatar
ill make it easy for you. yes they (Si and EX) have the same spline count. but the SI and EX are NOT the same knuckle.
here are pics of the stamping found on 90-91 Civic Sedan EX knuckles. and right next to them is a comparison with my old SI set up. you can see the difference right away. and NO your legend calipers will not work with anything other than the EX knucles (and DA) on an 88-91 civic/crx chassis.
pics are of the brake set up on my 90 DX
Old 08-01-2011, 07:44 PM
90_EX_Civic's Avatar
DX, SI, EX, same spline count. HF is the one with the different spline.
and like Tyson said, you can't just BOLT ON legend front brakes.
^^^ beat me to it
Old 08-01-2011, 08:43 PM
Then WTF is this guy talking about????? Different setup then what I'm talking about but he is claiming 88-00 Ex/Si Front Knuckles.
http://madfablab.com/product_info.ph...products_id=40
Old 08-01-2011, 09:16 PM
crx_si-r's Avatar
by the sounds of this you are attempting to mimic the set up without having done the proper research on the brake upgrade.
Old 08-01-2011, 11:32 PM
Tyson's Avatar
its nonsense.
Old 08-02-2011, 07:36 AM
Yes I am & I have researched... You guys are the only 1's saying I can't do what I wanna do. Everything else I have read says EX/Si knuckles will work...
Old 08-02-2011, 10:16 AM
SuicideError's Avatar
It should work. Axles are sold for the EX in 23 and 26 spline. Easiest way is just to count the spline.
Old 08-02-2011, 06:33 PM
OK I most likely got a set of EF EX knuckles coming a guy on here so I won't have to worry about that part anymore...
ElCivic89
05-14-2011 06:21 PM
modman
Honda Civic (2006 - 2015)
28
08-21-2006 10:45 PM
acuratech
01-24-2005 01:37 PM
2 point 0
05-18-2004 09:39 AM
Propulsion
03-26-2002 03:51 PM
Quick Reply: CRX/Civic Si/Ex Front Suspension Questions
