swapping speedo. wire harnes?
alight so i have a 91 crx si that has a speedo, that does not work but has the tach, and everything except speedo, and milage working, and i have an 88 crx si that i dont know if anything in it works or not but lets assume/hope that they do. so want to swap whatever wire is the speedo wire to get mine working, can i do this? how do i do this?
Re: swapping speedo. wire harnes? (stemiched)
Have you made sure the speedo cable isn't broken and is connected at the transmission and the speedo head? If so, you can swap just the speedo if it is by the same manufacturer. It should be stamped NS or ND on the back. By swapping speedo only you will not have to change the wiring to the cluster.
Re: swapping speedo. wire harnes? (wood 1)
i did check to make sure it was pluged into the speedo. and it is, i am not fully sure where it gets pluged into the trany. and im not sure how to check if it is broken or not. and without looking at the back of the speedo. i can tell there not the same ones, they look different.
The speeedo cable comes out of the firewall and into the transmission to the right of the rear tranny mount, as you face the car. Locate the cable and try to push it down into the transmission, that might be the problem.
As far as your clusters go, 88-89 has a flatter top edge. If you swap it into a 90-91 car, you will have to also change the housing and do some rewiring. hopefully the cable just came out of the transmission.
alright yea i noticed that the 88-89 is flatter, ill go figure out if i can do what you just sead, if not i think ill take it to a mechanic that knows this stuff... im getting tired of dealing with it myself... thanks for the help
solerizr
03-09-2007 03:01 PM
