speedo and gas gauge not working with swap?
Old 06-11-2009, 08:25 PM
JDMforlifeOH's Avatar
Default speedo and gas gauge not working with swap?
i have a 91 crx with a z6 swap and my speedo and my gas gauge dont work and i bought the car this way, what could i check? or is my cluster bad?
Old 06-11-2009, 08:28 PM
frank_el_tanke's Avatar
Default Re: speedo and gas gauge not working with swap?
what have u checked so far?
Old 06-11-2009, 08:29 PM
KRock459's Avatar
Check all fuses and factory grounds first. Next, remove the cluster and check for ignition and ground, if you search you will find a pinout with colors which will make things easier.
Kirk R
Old 06-11-2009, 08:35 PM
i havent checkd anything yet iv just finished the whole car except for this cluster problem and figured id ask on here and work on it tomarrow
Old 06-11-2009, 08:37 PM
Kirk R
do i find the pinout for the ignition? grounds? cluster?
Old 06-11-2009, 08:43 PM
KRock459's Avatar
pinout for the cluster plugs. The back of the cluster is marked if you look close, it will say IGN for ignition, GND for ground, test a few points and see what you find.
Kirk R
Old 06-11-2009, 08:52 PM
Kirk R
but isent the speedo mechanical?
Old 06-11-2009, 09:02 PM
KRock459's Avatar
Depends on the cluster and the vehicle. Most hondas 91 and older are cable drive, 92 and newer electronic. If the speedo is cable driven and not working, my guess is a faulty cable, or the incorrect mechanical VSS unit in the tranny.
Does part of your cluster function?
Kirk R
Old 06-11-2009, 09:07 PM
yes, the speedometer is mechanical... unplug it from the back of the cluster. leave it unplugged and drive down your street if you see the cable inside spinning then it's your speedometer reader.
as far as the fuel gauge, first check to see if the fuel gauge sending unit is even plugged in.
Old 06-11-2009, 09:14 PM
Kirk R
mine is cable,
yes my rpm and temp gauge both work on the cluster just the other side quiet working
Old 06-11-2009, 09:16 PM
the cable does spin my buddy messed with it, and he also messed with the fuel gauge aswell and everything is plugd in and wired correctly,
could just half of my cluster go bad?
Old 06-11-2009, 09:19 PM
what do you mean when you say he messed with it?
Old 06-11-2009, 09:22 PM
he tried to fix it, he couldnt find anything wrong with it but he dident check anything in the cluster thats why i thoght maybe half my cluster went out but i dont know thats just my guess
Old 06-11-2009, 09:28 PM
how did he check it? did he just checked to see if the cable rotated, did he pull out the vss to see if it worked properly?
try and borrow a 90-91 civic or crx cluster, it doesn't matter if its for a dx or si. plug it in and see if your fuel gauge and speedometer work.
Old 06-11-2009, 09:36 PM
yes he checked the cable and it rotated, and he did not do that
oky that will be very hard to find around here but i will definitely give that a try
MTarry
11
01-15-2013 06:46 PM
utn
Honda Civic (2001 - 2005)
11-12-2007 01:48 PM
turbod16y7vtec
11-19-2004 07:11 PM
oh-k
09-14-2004 06:40 PM
Quick Reply: speedo and gas gauge not working with swap?
