Steering wheel vibration
Old 09-14-2001, 11:09 AM
raene's Avatar
Default Steering wheel vibration
The steering wheel on my CRX vibrates so much sometimes it makes noise... it literally blurs as it's shaking around. If I grab it the vibration is lessened a lot. Is there any way to tighten it up, or is this normal?
Old 09-14-2001, 11:24 AM
New User
quidquam's Avatar
Default Re: Steering wheel vibration (raene)
probably an unbalanced wheel or warped rotor.
Does it vibrate always, or only at a certain speed?
Check those first.
Old 09-14-2001, 11:25 AM
RyanR's Avatar
There are a few things it could be. Either a bent rim, worn ball joints, worn outer tie rods, warped rotors or worn wheel bearings. If you have warped rotors then you'll usually only get vibration under braking.
Old 09-14-2001, 12:02 PM
New User
gutted spec's Avatar
Default Re: Steering wheel vibration (97TypeR_9)
Mine used to do that.....and the steering would wander a lot on the highway. Once I replaced the rack, it tightened right up and stopped vibrating.
Old 09-14-2001, 02:21 PM
91ED7Si's Avatar
Default Re: Steering wheel vibration (realdealb16)
yeah mine does that **** too..
the faster i go the worse it is.
im pretty sure mines a combo of bad alignment and warped rotors.
mine makes noise too dudduddudduddududududududud
[Modified by 91ED7Si, 11:21 PM 9/14/2001]
Old 09-14-2001, 03:16 PM
clockworks's Avatar
Does it do it at idle? It might be the motor mounts.
Greg
Old 09-14-2001, 05:32 PM
Denny317's Avatar
it's most likely bad alignment...mine rattled too...and still does!
Old 09-15-2001, 10:22 PM
raene's Avatar
Default Re: Steering wheel vibration (clockworks)
Sorry that was totally unclear . It only vibrates at idle... it's solid at speed.
I'd think it was the mounts too except that it used to do that with the D16A6 too. I just thought it was normal.
Old 09-16-2001, 03:28 PM
Banned
W0oT's Avatar
how is your idle?? your idle could be the cause. and i think you were saying you have a b16 w/ idle probs right? i may be wrong it was on another post. if you are haveing idle problems that could def be it. mine does it only when it drops below 750rpms
Old 09-16-2001, 07:28 PM
raene's Avatar
Default Re: Steering wheel vibration (Nismo240sx1)
It does vibrate a lot more when the idle drops, but at 750 rpms it vibrates enough to make a rattling noise out of the plastic cover...
Old 09-16-2001, 09:39 PM
Banned
W0oT's Avatar
is the cover loose?? should be tightly secured to the column.. i donno something else could be loose if not. but then i would think it's a motor mount.
Ohbebe75
10-24-2015 07:50 AM
miked198729
08-17-2013 06:38 AM
teletekman
05-03-2006 09:15 AM
98ITR681
06-27-2003 12:06 PM
E dwinbon G
01-12-2003 11:04 PM
Quick Reply: Steering wheel vibration
