sohc d-series vs dohc zc intake manifolds
Old 06-28-2007, 01:25 PM
metlmadman's Avatar
Default sohc d-series vs dohc zc intake manifolds
Does anyone know if there is a flange/ bolt pattern difference between the late model sohc d-series and the dohc zc intake manifolds? or are all d-series intake manifold bolt patterns the same?
Just wondering, can I use a late model D-series supercharger on a zc engine with minimal tweaking?
or
Old 06-28-2007, 01:28 PM
Rainman
SIred91's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (metlmadman)
The bolt pattern is different......jlicrx or zcspeed.com can hook you up with an adapter plate though...
All D series bolt patterns are the same EXCEPT the DOHC ZC.
Old 06-28-2007, 01:41 PM
Autoworks's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">The bolt pattern is different......jlicrx or zcspeed.com can hook you up with an adapter plate though...
All D series bolt patterns are the same EXCEPT the DOHC ZC.</TD></TR></TABLE>
hit the nail on the head
I would not try to force a JRSC on with an adaptor though
Old 06-28-2007, 01:59 PM
89efDUSTY's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (Autoworks)
All D series bolt patterns are the same EXCEPT the DOHC ZC.</TD></TR></TABLE> I dont believe that is entirely true, my d16a1 manifold did not line up with my d16a6.
With the adapter plate supercharging may be bad like Autoworks said because high probability of a intake leak.
Old 06-28-2007, 02:01 PM
metlmadman's Avatar
nice, quick responses
thanks guys
Old 06-28-2007, 02:06 PM
Rainman
SIred91's Avatar
Default Re: sohc d-series vs dohc zc intake manifolds (89efDUSTY)
Okay.....DOHC D series intakes are not compatable with SOHC D series....
There.
Old 06-28-2007, 02:08 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> I dont believe that is entirely true, my d16a1 manifold did not line up with my d16a6.
With the adapter plate supercharging may be bad like Autoworks said because high probability of a intake leak. </TD></TR></TABLE>
D16A1 should be the same as ZC, I'm sure jilicrx will know for sure, but I am pretty sure that's correct.
Actually, that is correct, the insulated Intake Mani gasket I used on my ZC was for a D16A1 86-89 Integra.
The reason I wouldn't try to force the JRSC on with an adaptor is due to it moving the JRSC back and not ligning up correctly on the pulley side. I'm sure it could all be fixed, but it would be more time and headache than it's worth probably. (pulley tensionor, different belt lengths, pulley alignment...one more reason to turbo )
flatblackfury91
09-12-2012 05:40 AM
JDMbitches
10-09-2006 04:07 PM
ilovemyb16a
72
04-26-2006 07:54 PM
Ekay Jay
06-06-2004 07:17 PM
puhlode
05-10-2003 11:31 PM
Quick Reply: sohc d-series vs dohc zc intake manifolds
