si cluster into dx
Old 01-22-2010, 10:46 PM
hondanator88's Avatar
Default si cluster into dx
ok so i need to know what wires i need to switch around in those 2 plugs in the back of the cluster from my dum dx cluster into my 88 89 cluster please help or send diagram thx guys and o ya when is the seattl meet again?
Old 01-22-2010, 10:58 PM
miguey310's Avatar
Default Re: si cluster into dx
it's jus plug and play
Old 01-22-2010, 11:08 PM
90_EX_Civic's Avatar
unless op got the wrong year cluster? thought 88-89 and 90-91 only.
Old 01-22-2010, 11:26 PM
martn53's Avatar
88-89 clusters plug n play
90-91 clusters plug n play
if u got the wrong one u would have to re wire
Old 01-23-2010, 09:05 AM
thevtecnician's Avatar
Just take a very thin specialty screwdriver and de pin all the wires from the cluster plugs. And then put the pins back in exactly like they are in this picture:
You shouldnt have to cut anything and this should be a 15 minute project max.
Also If you're going from an 90-91 cluster to 88-89 you're going to need an 88-89 civic cluster cover.
I thought the car was a 90-91. if it's an88-89 it is plug and play like said above.
Old 01-23-2010, 01:02 PM
HTautodc's Avatar
odd. because i have a 90 dx, got a 90 si cluster, swapped it to my dx. it works fine except when the ignition if off. if the ignition is off, the door indicator is working the other way (the door indicator would turn on if the door is closed and would turn off if the door is open)
Old 01-30-2010, 08:05 PM
wow thx for that picture but the thing is that its not plug and play the cluster i have is out a of a 88 four door lx. cuz it has the trunk light but im sure its a 88 89 cluster cuz look at my pic it is the one i have ill post a pic again when im dont but true the plug lay u just gave me is that the way it needs to be for a 88 dx hatch and si cluster or "lx" sluster persay?
Old 10-24-2010, 05:49 PM
todubbled1's Avatar
Actually I just purchased an 89 si cluster. Put it in and it was not plug and play at all. I really would like to know what needs to be repinned. And on the diagram I have no clue what the switched power to fuse # means. Thanks.
Old 10-24-2010, 06:00 PM
Crazy Honda Guy
Deetz's Avatar
Here's what a lot of people don't know.......
there are "two" different companies that make clusters......ND and NS
In order to be plug and play, you need to have the same style cluster 88/89 into an 88/89 car, and it has to be the one mfg'd from the same company....same goes for the 90-91 style into a 90-91 car
The NS or ND stamp is right in the gauges in the cluster
i'll screw up the spelling but here goes, lol
ND= Nippon Denzo
NS- Nippon Sieki
Old 10-24-2010, 06:55 PM
hushypushy's Avatar
^ pretty sure it's Nippon Denso and Nippon Seiki. You were close though.
I didn't know that it had to match the same brand. I guess I've just gotten lucky in the past
Old 10-24-2010, 08:38 PM
todubbled1's Avatar
I have an 88/89 dx and I put an 88/89 si cluster. Didn't work for me at all. The cluster does work. I seen it myself. Thanks.
Old 10-24-2010, 09:42 PM
Crazy Honda Guy
Deetz's Avatar
lol, you didn't read my post!
Old 10-25-2010, 08:02 AM
chafetzk's Avatar
You say that it's plug and play for an 88-89 dx but what about a standard. My civic hatchback doesn't even have the door sensors
Old 10-25-2010, 02:08 PM
todubbled1's Avatar
Both of mine are ds by the way.
Old 10-25-2010, 02:36 PM
singlecamsaint's Avatar
mines a standard and its plug and play, just got a 89 lx cluster and it works just fine, pay attention to Deetz posts this guy knows what hes talking about
Old 10-27-2010, 01:47 PM
chafetzk's Avatar
Alright cool thanks
Old 10-30-2010, 11:39 AM
todubbled1's Avatar
Well Deetz. The wknd has come around to where I don't have to drive my car. Went out unistalled my 88 cluster. Which is an NS. Took the 89 NS si cluster. Plugged it in. Doesn't work. I know the cluster is functional. So here is what happens when it is plugged in. I turn on the car. Cel come on. My right blinker works great. Which is the only thing that works. I let my emergency brake down and my tach came up. I reved it and it moved just a tad. Pulled the emergency brake back up and tach went back down. Also when I put the left blinker on my cel light blinks. Any help would be awesome. Thanks
Old 10-30-2010, 03:55 PM
Crazy Honda Guy
Deetz's Avatar
Well, the only thing i can think of, and i haven't confirmed this at all, but heard it rumered was that wiring may be different on sedan models, which look just like Si clusters.....i have no idea if they are different or not.
When you do figure it out, make sure to post and let others know whats up
Old 10-30-2010, 04:10 PM
todubbled1's Avatar
Yeah I will man. I just don't get it doesn't make any sense to me. I just want a damn tach.
hondadx
04-11-2008 02:21 PM
Mr.Meowsome
12
12-04-2007 05:23 PM
Vaans
08-27-2004 05:21 PM
Layziebtnh055
04-20-2004 08:44 AM
Speedfreak
12-11-2002 04:43 PM
Quick Reply: si cluster into dx
