headlights
Old 08-11-2009, 08:15 PM
K.E.G.'s Avatar
Default headlights
hey, my headlights dont line up on my crx. one sits crooked and the other is sunk in, any ideas?
Old 08-11-2009, 08:21 PM
BiG ChOr!Zo's Avatar
Default Re: headlights
there should be a screw on the top of the headlights that you need to adjust with a phillips screwdriver to make them even...!!!
Old 08-11-2009, 08:53 PM
K.E.G.'s Avatar
no that adjusts height, i meane like one slants upper right to left and the other is sunk in, i think my brackets a messed up
Old 08-11-2009, 09:03 PM
Reject Papi
jhammond_82's Avatar
did you look at your brackets? or did you just notice it and post in here. lol. go check it out. take a pic while your at it too.
Old 08-11-2009, 09:06 PM
K.E.G.'s Avatar
I looked at them, and i cant tell. I ripped apart my headlights to set them back to how they were but there was nothing to do. I do know that the sunk in one came back out but when i put the bumper support back on it pushed it back, but I kinda want to keep the support, there are some crazy *** drivers here in minnesota
Old 08-11-2009, 10:07 PM
enigma2446's Avatar
this can be a number of problems....1 it can be ur bumber......out of alighnment....2 is the hood on properley....3 is the top crossmember bent or has been modified?
Old 08-11-2009, 10:10 PM
michael O's Avatar
I'm not sure if my problem is the same thing. I can push one of my headlights back into the housing and have the light point into the sky. Is that similar to your problem?
I remote started my car into so many walls when I was younger...
Old 08-12-2009, 01:35 AM
EFB055
~sp33~'s Avatar
The bumper alignment doesn't affect the headlight positioning. Neither does the hood... Or the crossmember? What are you smoking.
Your headlight buckets bolt to the chassis, if it's not lining up properly, your car's probably been in an accident and the metal has been twisted. Take off your bumper, etc and check for creases or folds in and around the radiator and headlight shrouds. If that's the case, then you'll have to get crafty with your skills to get the headlights to sit straight.
Old 08-12-2009, 06:34 AM
K.E.G.'s Avatar
you know, I didnt see any creases but i do assume that it has been because of the front bumper and hood are black. But does anyone know if Sir liight would work, i thought they actually bolt onto the housing itself and not the bracket
Old 08-12-2009, 06:38 AM
grog's Avatar
you would need an sir hood and maybe bumper too.
Old 08-12-2009, 06:55 AM
K.E.G.'s Avatar
Oh I know. Im saving up to do an SiR conversion as we speak.
em2~b!tch
Honda Civic (2001 - 2005)
01-20-2010 12:32 AM
imsickofrice
Paint and Body
18
02-03-2009 05:17 PM
cimo463
04-02-2008 01:18 PM
Mrx733
04-23-2006 07:57 PM
sir91
11-30-2003 02:27 PM
Quick Reply: headlights
