is oversteer possible in a CRX, HOW
Old 11-14-2005, 06:46 PM
HondaHeddie's Avatar
Default is oversteer possible in a CRX, HOW
Can one xfer enough weight to stop the endless understeer?
btw
I dont want to put bags of cement in the back either
Old 11-14-2005, 06:48 PM
sidewayz32's Avatar
Default Re: is oversteer possible in a CRX, HOW (aal)
e-brake?
Old 11-14-2005, 06:53 PM
Default Re: is oversteer possible in a CRX, HOW (sidewayz32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidewayz32 &raquo;</TD></TR><TR><TD CLASS="quote">e-brake?</TD></TR></TABLE>
I am not trying to pull stunts
When I go around hwy exits/entrances or am otherwise having fun during daily driving the front slides.
maybe I should put Pirrelli on the front and some nice hard, long mileage tires on the back.
Old 11-14-2005, 06:56 PM
g-ride-si's Avatar
mine does all the time, stiff suspension, sticky fronts hard rears(tires). i also usually have my sub and amp in the back. i even have a big heavy b18 in the front but itll kick the *** out all day long.
Old 11-14-2005, 07:01 PM
Coltmorris's Avatar
Default Re: (g-ride-si)
front wheel drive cars dont really 'oversteer' the way one would ever want. Any kind of serious oversteer in a crx is dangerous and stupid. if you just want to eliminate understeer dont just lighten the back up a whole bunch your car will be really unbalanced. it depends what kind of oversteer your talking about tho..lift off oversteer is the kind attainable with a crx any other kind is pretty much for rwd cars. Just get your car balanced do some research. If you want oversteer get a rwd car
Old 11-14-2005, 07:05 PM
Default Re: (Coltmorris)
I just want to end the understeer
I am not trying to cut donuts
I have nothing but a full size spare in the rear
no sound sys at all...........that will come later
after I am done mechanically
Old 11-14-2005, 07:14 PM
CRXBart's Avatar
Location: Land of the free, whoever told you that is your enemy
ST rear sway bar, and stiffer rear spring rates.
Old 11-14-2005, 07:15 PM
g-ride-si's Avatar
mine only kicks out when i get out of the throttle or cut the wheel. very controllable. not dangerous at all if you know what your doing.
Old 11-14-2005, 08:40 PM
D Jaws II's Avatar
Default Re: (aal)
aal,
What year and model of CRX? some major differences in suspension between generations, that's why i ask. Street use only?
Donnie
Old 11-14-2005, 08:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">mine does all the time, stiff suspension, sticky fronts hard rears(tires). i also usually have my sub and amp in the back. i even have a big heavy b18 in the front but itll kick the *** out all day long.</TD></TR></TABLE>
the b18 is probly why you can sling you rear.
it is levering your rear off the ground
Old 11-14-2005, 08:50 PM
D Jaws II's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">mine only kicks out when i get out of the throttle or cut the wheel. very controllable. not dangerous at all if you know what your doing.</TD></TR></TABLE>
You do that on a 30 degree high banked asphalt track and you'll find new uses for Depends. Not dangerous ,very controllable....hardly, your heart will skip a beat, I guarantee it.
JMHO
Donnie
g-ride-si's Avatar
Default Re: (aal)
i know sometimes i even get the 3 wheel motion in there.
Old 11-14-2005, 08:53 PM
peanut butter's Avatar
If you have a front sway bar on take it off. I took mine off and it reduced the understeer by a lot and turn-in on corners was a lot better too.
Old 11-14-2005, 11:34 PM
g-ride-si's Avatar
Default Re: (D Jaws II)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D Jaws II &raquo;</TD></TR><TR><TD CLASS="quote">You do that on a 30 degree high banked asphalt track and you'll find new uses for Depends. Not dangerous ,very controllable....hardly, your heart will skip a beat, I guarantee it.
JMHO
Donnie</TD></TR></TABLE>
i used to do it all the time in my late model modified, im used to being sideways. of course that is rwd, im not saying it wont scare you the firs time but try it in an open parking lot, that way if it ever happens accidently youll know what to do with the car, in fwd if you give it gas it tends to straighten out pretty quick.
Old 11-15-2005, 04:38 AM
MEAT PATTY
goforbroke's Avatar
I don't have a crx but a hatch and having a lot of understeer on the road is dangerous. I spun out numerous times, given sometimes I was messing around but other times I was driving normal. If you autox or did road racing it was be acceptable. Oversteer is a crx is dangerous because its hard to correct it with such a short wheelbase. People will give you countless setups that will work for you I'm just not going to do it.
Old 11-15-2005, 07:13 AM
Hondacivic90ed's Avatar
I lift thottle understeered my DA into a barrell roll down an embankment where the roof caved in and my head had road rash. I still relive it today. Understeer is bad, oversteer is bad, if you really want a good time, balance your car so that it is predictable and handles turns not slides through them.
Old 11-15-2005, 08:01 AM
Timmah!!'s Avatar
Default Re: (Hondacivic90ed)
1)Install Rear ST swaybar on its tightest setting
2)Uninstall front swaybar
3)Install Mugen rear trailing arm bushing
4)Trail-break into the corner
I can assure you, you will have all the oversteer you could ever want
Old 11-15-2005, 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D Jaws II &raquo;</TD></TR><TR><TD CLASS="quote">aal,
91 STD (according to the manual Honda quit calling them DX in 89, hence the lack of a badge)
5spd
ac removed
yes street use, daily driver, with some cross country(long hwy drives)
Old 11-15-2005, 02:06 PM
Boosted Chemist's Avatar
Default Re: (aal)
get a st rear sway, but watch it, i almost lost my car due to oversteer (had the st at the highest setting)
Old 11-15-2005, 02:13 PM
EJ1 wilcox's Avatar
Default Re: (Boosted Chemist)
Stiff springs in the back and a nice thick sway bar.
In my EF project I'm running a ST sway in the back with a Si sway bar up front. That with strut bars and skunk2 coilovers should make my car pretty neutral.
My goal is to get the car as neutral as possible. I used to have a DA that was so neutral it was amazing. It was so predictable, even if I went into a corner too hot I never felt out of control. That thing would slide perfectly flat without understeer or oversteer.
That's my goal with this EF. Predictability even when skidding
IMO that's much better than simply getting a FWD car to oversteer.
Old 11-15-2005, 03:36 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">Stiff springs in the back and a nice thick sway bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">get a st rear sway, but watch it, i almost lost my car due to oversteer (had the st at the highest setting)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cobra Tim &raquo;</TD></TR><TR><TD CLASS="quote">1)Install Rear ST swaybar on its tightest setting
I can assure you, you will have all the oversteer you could ever want </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peanut butter &raquo;</TD></TR><TR><TD CLASS="quote">If you have a front sway bar on take it off. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">ST rear sway bar, and stiffer rear spring rates. </TD></TR></TABLE>
Old 11-15-2005, 03:41 PM
CRXBart's Avatar
Default Re: is oversteer possible in a CRX, HOW (88 rex)
This thread is begining to look like a ST comercial. lol. Seriously though, it is one of the best mods you can do to an EF. I don't try to drift my car's by any means, but it kills the understeer problem. I need to change the setting on mine on my beater now, though. I went to 205's and now the damn thing pushes again, time for the full stiff setting.
Old 11-15-2005, 04:16 PM
Default Re: is oversteer possible in a CRX, HOW (CRXBart)
ok
I wasnt really looking to have oversteer
I just wanted to get rid of understeer.
Sounds like you guys have my answer
-----------------what is the $$ on these mods------------------
other than the JDM D15B it is as it came from the factory
(no coils, sway bars, or anything)
Old 11-15-2005, 04:33 PM
jisu009's Avatar
Default Re: (aal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aal &raquo;</TD></TR><TR><TD CLASS="quote">
5spd
ac removed
yes street use, daily driver, with some cross country(long hwy drives)</TD></TR></TABLE>
The STD is a civic hatch. It was a 4 sp transmission.
The CRX models were:
SI, DX and HF
Old 11-15-2005, 04:36 PM
Default Re: (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">The STD is a civic hatch. It was a 4 sp transmission.
SI, DX and HF</TD></TR></TABLE>
I bow to your knowledge
I just reread the manual, I missed that.
I have a DX.
Did they have a DX badge on them in 88-89?
85-87?
Quick Reply: is oversteer possible in a CRX, HOW
