Outa gas....Needle on E or redline?????
Old 02-02-2005, 03:29 PM
groundedcivic91's Avatar
Default Outa gas....Needle on E or redline?????
never had my car that low. And the 89 Hatch doesn't have a feul light, as far as I know.
So whats empty, needle on the E or needle on the Red Line?
Old 02-02-2005, 03:37 PM
shawn_crx's Avatar
Default Re: Outa gas....Needle on E or redline????? (groundedcivic91)
the Redline.
I always pump it about 1/4 left. don't want to get stuck in the middle of nowhere
Old 02-02-2005, 03:40 PM
Keyboard Humorist
4drEF's Avatar
Mine goes empty and stops running when the needle dips just a little under the red line.
That's my car though.
The only way to really find out on yours is to empty the tank or run it dry.
Old 02-02-2005, 03:45 PM
Tyson's Avatar
the factory guages arent really calibrated to any tight tolerance. each car/guage will be different. just gotta know your car.
Mr_CRX's Avatar
Default Re: Outa gas....Needle on E or redline????? (4drEF)
Mine can go about 1/8" below the bottom of the red line.
Don't ask me how I know
Old 02-02-2005, 03:56 PM
88DXCRX's Avatar
Location: I told you to wait in the truck in Texas, United States
Default Re: Outa gas....Needle on E or redline????? (Mr_CRX)
You guys do know that running a car with an electric in-tank pump
low on gas is not a really good idea right?
Besides picking up all the crap off the bottom of the tank,
The fuel pump relies on the fuel around it to keep it cool..
Read this: http://www.commuter-register.org/runempty.html
for more info..
Old 02-02-2005, 04:10 PM
i just fill up at the line but only takes like 8-9 gallons usually so i guess im good for a little below line, just scared for the above issue of cooling and sucking up stuff from tank
Old 02-02-2005, 04:13 PM
BANNED
krazie1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">the factory guages arent really calibrated to any tight tolerance. each car/guage will be different. just gotta know your car.</TD></TR></TABLE>
very true!
Old 02-02-2005, 04:14 PM
31flavorscivic's Avatar
I filled up 11 gallons today . Never ran it out that far before. Kinda scared me when I saw the numbers on the pump. Mine goes a little below the line.
Old 02-02-2005, 04:15 PM
Default Re: Outa gas....Needle on E or redline????? (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">You guys do know that running a car with an electric in-tank pump
for more info..</TD></TR></TABLE>
Know of someone who once had a suburban that made that mistake. My dad got a call and had to drive an hour and a half to get the guy from somewhere out in the middle of nowhere.
edit: **** I meant to hit edit on that last one. Crap.
Old 02-02-2005, 04:20 PM
91civicEX's Avatar
according to the manual when it hits the redline then you have 1 gallon left
Old 02-02-2005, 04:25 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groundedcivic91 &raquo;</TD></TR><TR><TD CLASS="quote">i just fill up at the line but only takes like 8-9 gallons usually so i guess im good for a little below line, just scared for the above issue of cooling and sucking up stuff from tank</TD></TR></TABLE>
you know the fuel pump inlet just sits at the bottom of the tank anyway. its not like running low would cause any more drudge that would be in there to occur.
Old 02-02-2005, 04:45 PM
88DXCRX's Avatar
Default Re: Outa gas....Needle on E or redline????? (Tyson)
That is debatable..
As long as it is saturated,the filter sock absorbs fuel from all around it..
It picks up the fuel which offers the least resistance..
At near empty,it pulls from directly beneath it because
that is all that is avalible..
Old 02-02-2005, 09:31 PM
trustnoone7935's Avatar
Default Re: Outa gas....Needle on E or redline????? (88DXCRX)
[QUOTE=88DXCRX]That is debatable..
agreed, plus i've always heard it's not good to run fuel injected cars all the way dry screws up the system or something
Old 02-02-2005, 10:01 PM
Needs to be About 20% Cooler
DieMaster's Avatar
Default Re: Outa gas....Needle on E or redline????? (trustnoone7935)
on mine the bottom if the redline is bone dry. I thought i could squeeze one more Arron out of the tank and it died on the freeway lol even at WOT the car ran like **** not even an idle. maybe 200 rpm. any way i filled it up and it said ~10.8 gallons and this was back (in CA ) when gas was $2.60 a gal i wana put a light on mine so it dosent happen again
EDIT: LOL my dad got his tacoma out there on the freeway and all we could find was the dog's leash it was suprisingly strong though and my dad "towed" me to the gas station
Old 02-03-2005, 04:33 AM
RACINTWEEK's Avatar
Default Re: Outa gas....Needle on E or redline????? (DieMaster)
acording to my owners manual for my 91 std, capacity is 11.? us gallons
And from the top of the red line you have 1.1 us gallons left
most ef's have the same tank but i think the HF's have a smaller one
Old 02-03-2005, 04:34 AM
Twilight's Avatar
Default Re: Outa gas....Needle on E or redline????? (RACINTWEEK)
According to Civic Coupe CRX owners manual it says when the needle hits E, you have reservior tank left 3litres.
Old 02-03-2005, 05:01 AM
deftones0817's Avatar
Default Re: Outa gas....Needle on E or redline????? (Twilight)
The really sad part is my gas gauge doesnt work anymore and honda doesnt make fuel sending units for 89 crxs hfs anymore and they are different from si...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">on mine the bottom if the redline is bone dry. I thought i could squeeze one more Arron out of the tank and it died on the freeway lol even at WOT the car ran like **** not even an idle. maybe 200 rpm. any way i filled it up and it said ~10.8 gallons and this was back (in CA ) when gas was $2.60 a gal i wana put a light on mine so it dosent happen again
EDIT: LOL my dad got his tacoma out there on the freeway and all we could find was the dog's leash it was suprisingly strong though and my dad "towed" me to the gas station </TD></TR></TABLE>
That is awesome story...lol dog leash.
Old 02-03-2005, 05:26 AM
DaX
DaX's Avatar
I totally ignore the gauge. I use the trip meter. I can get AT LEAST 360 miles per tank, so I try to fill up when I hit the 340-360 range.
Old 02-03-2005, 05:29 AM
92integra_gs's Avatar
AMEN!
nick77538
Motorcycles
07-07-2017 08:59 AM
Pelikan
05-22-2015 05:57 PM
blacK_Dc4
21
06-03-2014 10:22 PM
slvrslepr
08-20-2008 06:07 PM
Big Teggie
12-23-2007 10:13 AM
Quick Reply: Outa gas....Needle on E or redline?????
