No start condition
No start condition
Stored EE2 Wagovan for an extended period of time and when i went to crank her up, the motor turned firmly then after that i went to turn he ignition again and nothing. Not even a click from the starter... Checked the engine bay fuse panel and they're good. haven't checked the knee plate drivers fuse box YET though. When i hot wire the starter to the battery the engine turns so it would seem as if they're a blown fuse. Anyone else run into this?
Re: No start condition
So it cranks but doesn't start? Or it cranked but now it doesn't crank any longer? if it cranks, I would just crack the line on the fuel filter, or on the fuel rail. if fuel comes spraying out, than you know you have fuel pressure. but if it doesn't crank at all, that's where you have to start. lol
EFB055
The main relay will not prevent the motor from turning over, it stops the fuel pump from pumping. The motor will turn over, but the car will not start.
Check your fuses, and check your battery is good. A battery that's low can do funny things.
Did you replace the fuel? Could be stale.
yusoslo
04-21-2004 08:44 AM
