88 SI Restore Questions, Mainly Electrical
Old 03-04-2012, 09:12 AM
91GEDHATCH's Avatar
Default 88 SI Restore Questions, Mainly Electrical
I really need help with the turn signals if anyone has the experience, I've tried the flasher, fuses, bulbs, and I get nothing. No hazards, no green arrows, no click, nothing at all. Thanks!
Picked up a new 88 Si with the intent to restore its condition etc.
Well, I got it not running, swapped my B18 in it, rebuilt suspension and steering rack with ES Master kit.
Right now it runs great, but I have no turn signals, like no arrows, no front or rear lights nothing. What's my best starting point to track down the cause and keep in mind, I SUCK with electrical. Checked fuses, all good.
Now also, when I start the car, it primes, stops, fans kick on, and all is normal, starts fine etc., but the check engine light does not flick on for the 2-3 seconds like it's supposed to. Is this an issue? I'm not throwing any codes at all.
Last for now, the temp gauge is not working, I'm sure this is easy but if you know where to start that would be great.
I will also need a OEM hood to get rid of the awful and hideous scooped carbon fiber hood. It's yours free if you replace it with an OEM ha ha!
Thanks!
Last edited by 91GEDHATCH; 03-06-2012 at 05:05 AM. Reason: I aint figger it out none yet.
Old 03-04-2012, 11:23 AM
shiroun's Avatar
Default Re: 88 SI Restore Questions, Mainly Electrical
Thanks!
Well, i've got a 90 HB with an OEM hood. I'd like a scooped hood, so if you're anywhere near NY and want to run by then it's yours. Fair note, it has two stripped bolts.
Ground the temp gauge, it'll work.
Old 03-04-2012, 11:37 AM
91STDFLOW's Avatar
Check all wires that you touched, I did this once with my steering rack and side arms and had no turn signals, had it plugged into wrong spot doh
Heres some wiring diagrams to read
http://www.hondahookup.com/manuals/
Old 03-04-2012, 05:20 PM
91GEDHATCH's Avatar
Actually yes, I'll be in NY, but I don't know how to get the hood on the plane. Thanks for the diagram link, the signals actually had not worked before I did the swap, so there is a break somewhere. Looking into it over the next few days. Still haven't found an answer to the CE light at start.
Old 03-04-2012, 09:29 PM
bradley's Avatar
Where are you? I have a couple hoods.
Old 03-04-2012, 10:42 PM
Stunna MIKE's Avatar
Thanks!
First lets check to see if the sending unit wiring is good. Turn the ignition on, have some one, or yourself, ground out the plug for a second (shove a wire in the plug, harness side, and touch ground). Have another person, or yourself, check to see if the needle goes way up. If that works, the wiring is good and its your sending unit that is bad. If not, you have an open circuit. It's only 1 wire feeding directly to your cluster. Somewhere in my harness mine was bad, I just bypassed the whole harness and ran it direct. Has been working for a couple months now.
Now, for the hood. Where are you located ?
Old 03-05-2012, 03:49 AM
91GEDHATCH's Avatar
Ill have to see if that makes sense once im looking at it. Sounds pretty straight forward though on the gauge.
Im in Nashville fyi.
Old 03-06-2012, 05:08 AM
91GEDHATCH's Avatar
Help? Please?
Old 03-06-2012, 09:09 AM
91GEDHATCH's Avatar
Turn signals were not working due to a faulty hazard switch.
Now can anyone help me with the Check Engine light not coming on when I turn the key to run or are we all too busy arguing about where to get JDM paint jobs and clean headlights?
MyNamesMatt
03-03-2013 08:15 AM
socialistic
54
02-13-2011 05:11 AM
rbwdriven
10-24-2008 02:54 AM
pandacivic
07-28-2005 08:44 AM
Quick Reply: 88 SI Restore Questions, Mainly Electrical
