how to chek tranny oil
Old 05-10-2006, 11:02 AM
1991hondahatchsi's Avatar
Default how to chek tranny oil
i dont know how to chek my transmission oil
Old 05-10-2006, 12:27 PM
S CARTER's Avatar
Default Re: how to chek tranny oil (1991hondahatchsi)
To check the tranny fluid level on a 5 speed...
Straight form any owners manual.
Check the fluid level with the transmission at normal operating temperature and the car sitting on level ground. Remove the transmission filler bolt and carefully feel in side the bolt hole with your finger. The fluid level should be up to the edge of the bolt hole. If it is not, add honda manual transmission fluid (MTF) until it starts to run out the hole. Reinstall the filler bolt and tighten it securely.
have fun
Old 05-10-2006, 09:31 PM
StorminMatt's Avatar
Default Re: how to chek tranny oil (S CARTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S CARTER &raquo;</TD></TR><TR><TD CLASS="quote">If it is not, add honda manual transmission fluid (MTF) until it starts to run out the hole.</TD></TR></TABLE>
You only want to add Honda MTF if that's what is already in there. If the transmission is currently filled with motor oil, then that is what you want to add. Or better yet, drain ALL the oil and refill with Honda MTF.
Old 05-11-2006, 02:40 AM
Maldito X's Avatar
and when you unplug it, if it's at the level it should be, the oil isnt gonna drain out?
Old 05-11-2006, 04:10 AM
S CARTER's Avatar
Default Re: (sLcREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLcREX &raquo;</TD></TR><TR><TD CLASS="quote">and when you unplug it, if it's at the level it should be, the oil isnt gonna drain out?</TD></TR></TABLE>
Correct
Old 05-11-2006, 11:58 PM
Maldito X's Avatar
So how do you drain it if you want to drain it? lol Is there two different bolts, or do you just put the car on uneven surface?
Old 05-12-2006, 02:09 AM
bc_ef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLcREX &raquo;</TD></TR><TR><TD CLASS="quote">So how do you drain it if you want to drain it? lol Is there two different bolts, or do you just put the car on uneven surface?</TD></TR></TABLE>
There's a drain bolt below. You use a 3/8" drive ratchet to loosen it.
Old 05-12-2006, 02:27 AM
downest's Avatar
Default Re: (bc_ef8)
Holy **** man, spend the 5 bucks and get a manual!
thanh4o8
09-17-2008 12:06 PM
Silent_Destruct
03-26-2006 01:07 AM
jeffroh22vtec
01-06-2006 08:56 AM
korndog
01-26-2005 02:16 PM
Slammd Sol
03-28-2004 10:21 AM
Quick Reply: how to chek tranny oil
