HF and SI injectors interchange?
Old 01-01-2006, 07:31 PM
shadycrx's Avatar
Default HF and SI injectors interchange?
ok i seached a lot for this and couldnt find a definite answer. can i use HF injectors in an Si setup? (si manifold, ecu etc. ) in other words are HF and SI injectors interchangeable
Old 01-01-2006, 08:11 PM
beyondspexj's Avatar
yup
Old 01-01-2006, 09:31 PM
highroller54's Avatar
Default Re: (beyondspecs_jamar)
arn't hf's dpfi? (we dont get hf's in canada) but I was sure they were dual points.
Old 01-01-2006, 09:51 PM
$cat /dev/urandom
sanimalp's Avatar
Default Re: (highroller54)
no. they are mpfi. only the crx dx is dpfi. the std and dx hatch are dpfi also, FYI..
and that is why hf's are awesome.. they are the lightest no frills model, with no mpfi wiring required for a b16/b18 swap.
and yes.. the injectors are identical.
Old 01-01-2006, 11:37 PM
njn63's Avatar
just in case you needed a 3rd yes, i have Si injectors in my 91 HF right now. They are the same.
Old 01-02-2006, 05:33 AM
shadycrx's Avatar
Default Re: (njn63)
awesome thanks for the help guys
Old 01-02-2006, 05:45 AM
godruler's Avatar
Default Re: (shadycrx)
i once heard hf injectors are only like a 185 cc flow rating? thats why i did'nt use mine when i put a B7 in the car
Old 01-02-2006, 06:45 AM
hatchinprogress's Avatar
Default Re: (godruler)
most of all honda injectors are 240cc (and thats what should be in your car)
Old 01-02-2006, 08:42 AM
Default Re: (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">no. they are mpfi. only the crx dx is dpfi. the std and dx hatch are dpfi also, FYI..
I agree
Old 01-02-2006, 09:11 AM
UltimX's Avatar
I agree that they arn' the same. the numbers on the injectors aren't the same as the si ones i have. anyone else care to chime in?
Old 01-02-2006, 09:36 AM
they were fine when i put them in my hf motor. never ran rich or anything either.
Old 01-02-2006, 07:03 PM
BlueCrxNC's Avatar
The 88-89 CRX HF Injectors do not flow the common 240cc... tested. But the 90-91 HF injectors are the same as the Si's.
sporkcrx
10-21-2006 01:07 PM
junkyardRx
09-06-2004 04:02 AM
Sampsonite987
03-30-2004 02:11 PM
Canonm7
05-04-2003 10:01 AM
Crxfanatic15
10
01-16-2003 10:49 PM
Quick Reply: HF and SI injectors interchange?
