Hesitation Issues when driving when letting go off gas **SWAP**
This son off a gun has hesitation issues when I am driving let go off gas and going steady speed foot on the gas the car slight jerks in all gears like its not getting any fuel or something.. I don't know..
I have a new fuel filter maybe I installed it wrong???
it was doing it with the old fuel filter also..
some shed some insights on this issue.
I think my dizzy is still good its only has about 5-8k mileage on it..
No CHECK ENGINE LIGHTS running OBD1 this problem just started happing...
if you know what is causing it let me know..
Modified by bossman032 at 5:33 AM 1/29/2004
threes
Re: Hesitation Issues when driving when letting go off gas **SWAP** (bossman032)
the car slightly accelerates after you let off the gas? is that what your saying?
be professional
Err . . . I don't understand.
The car is supposed to stop pulling after you lift off the throttle. When you coast in gear, the injectors cut the fuel.
Re: Hesitation Issues when driving when letting go off gas **SWAP** (c jackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c jackson »</TD></TR><TR><TD CLASS="quote">the car slightly accelerates after you let off the gas? is that what your saying?</TD></TR></TABLE>
Sorry guys. Will try to make it more clear.
say I am in gear all gears the problems happens. Like third gear like when I have my foot on the gas going steady speed the car hesitates/slight jerks it doesn't want to run normal this problem just started happening.
does this make little more sense. I know its not normal because it didn't used to happen
Re: Hesitation Issues when driving when letting go off gas **SWAP** (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">New spark plugs? Wires? Distributer cap and rotor? </TD></TR></TABLE>
might try that my dizzy is practily brand new **** sucks. also my wires and plugs have less then 5k mileage ngk the heavy duty stuff.
timing is correct
Modified by bossman032 at 6:36 AM 1/30/2004
timing is correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 »</TD></TR><TR><TD CLASS="quote">
I have my battery at the back can that cause it ran some fat speaker wires...?
only thing I did no check engine lights
timing is correct</TD></TR></TABLE>
When you say you're dizzy is new, is the entire thing (housing/bearings,coil,igniter,cap and rotor) new? If not that is probably where your problem lies.
Re: Hesitation Issues when driving when letting go off gas **SWAP** (CrxSi707)
MY DIZZY IS BRAND NEW ENTIRE **** FROM FLYING PAT U KNOW THE PEOPLE TO SELL HERE AND ADVERTISE HERE ON HONDA TECH.
I THINK THE DIZZY IS MY PROBLEM
Maybe my fucken STD fuel pump is dead??
when I smash the throttle no hesitation problem.
Only when I am driving normal and slowly acceleration that when it has hesitation problems.
Damn I have that problem to once in a while . I did change my fuel filter when I did my Z6 swap but I still get it once in a while like I said. Ya might be the freaking fuel pump not sure.
yes...have it right now...got b16a in 91 si hatch...i still havent figured it out...i replaced my dist. but it still happend...i just swapped o2 sensors so we'll see tom. morn.
Re: Hesitation Issues when driving when letting go off gas **SWAP** (R91Si)
keep me updated bro
I think is the fuel pump it works fine when I mesh the throttle
problem is getting worse and worse.
Hesitation is getting harder it jerks now
can the O2 cause it..?
I did change the fuel filter
I am thinking the dizzy, O2, fuel pump what else can cause it..??
I am thinking it cant be the sensor if they were messed up it will throw a CEL since its OBD1
my guess is either dizzy or injectors...
mine did that for a while and i ended up on the side of the road one day, so i replaced dizzy now its perfect.
Re: Hesitation Issues when driving when letting go off gas **SWAP** (CrXr89Si)
Are you using obd0 injecotrs? If so, try swapping to obd1 injectors and clips, and remove the resistor box. I had a problem like that, and i swapped over to obd0 injecotrs, on a obd1 setup, and it fixed it.
Re: Hesitation Issues when driving when letting go off gas **SWAP** (y49crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y49crxsi »</TD></TR><TR><TD CLASS="quote">Are you using obd0 injecotrs? If so, try swapping to obd1 injectors and clips, and remove the resistor box. I had a problem like that, and i swapped over to obd0 injecotrs, on a obd1 setup, and it fixed it.</TD></TR></TABLE>
running obd1 everything injectors etc..
also update on the problem: I am about empty on gas the problem has gone away soo I am thinking its the fuel pump I put 15buck off gas and its nearly empty now looks like the fuel pump is crapped out its running fine currently no Hesitation problems because I guess I have low fuel
Maybe, you have some water in your fuel? Condensation in the gas tank? When you fill up (or now) add some fuel injector cleaner or something along those lines to try to get rid of water in your tank.
It's a simple thing, but just a thought.
Re: Hesitation Issues when driving when letting go off gas **SWAP** (JesseR)
well i had this bog issue too as soon as i got my car swap..
like your slightly accelerating then it bogs.. so what i did is switch the o2 wires in my ecu..c8 and c16.. bog went bye bye.. haha. but the thing about that is i have obd0 i dont know about obd1 though.. does obd1 have two o2s?
