Hesitation Around 3K Rpm B16a 1st Gen.
Old 04-28-2007, 07:39 PM
Sanj's Avatar
Default Hesitation Around 3K Rpm B16a 1st Gen.
Hi Guys, need ur help, my car seems to bog at arond 3K rpm, no check engine light, replace everything cap, rotor, wires, plugs, pcv valve, air filter. Almost feels like its starving for gas then goes. I have stock injectors and an 99 siR fuel pump. Any suggestons would be helpful.
Thanks in advance.
Sanj
Old 04-28-2007, 09:49 PM
Slurp56's Avatar
Default Re: Hesitation Around 3K Rpm B16a 1st Gen. (Sanj)
My CRX did that after the swap and it turned out my O2 sensors were wired backwards. After I got the RPM's high enough to switch into open loop mode, the thing would clear right up. I switched the wires between the O2 sensors and then it ran good at all RPM.
Bustinvtec
25
08-12-2022 04:13 AM
95vtecsrus
33
08-12-2006 12:10 AM
JG90CRX-Si
05-11-2005 02:15 PM
MADEINIRAQ
07-26-2002 08:55 AM
Quick Reply: Hesitation Around 3K Rpm B16a 1st Gen.
