help i am extermly stuck ef b16 code 0 pump wont [rime
i have a b16a swapped ef. it worked fine until one day i was doing a pull and i shifted into secondad the fuel pump cut out. i replaced the fuel pump and it worked i straped the gastank back down. started it and it idled until it died seconds later and the engine light came on and stayed on. even if i jump the cel. i repined the ecu plugs to obd1 because thats what its running a chiped ecu obd1. i changed to another ecud the light goes away but still not prime from the fuel pump. i know the pump is okay i put 12v to from multiple sources. doubt its any grounds it ran before. the main relay is okay plus i have 2 working units. when i check voltge at the mainrelay plug the ecu isnt giving 12v to the relay with the ignition on with both ecus. i have no idea whats going on i am about ready to sell it for an evo its on craigslist in la if anyone is wants a cool project. but if i can fix it i will continue like i said i am about to blow my brains out. plus i know the wires that go to the ecu and pump from the main relay clip are okay i checked them. also the fuses seem to be okay but i still may replace them. could it be something in the engine harness. whats going one can someone please point me in a direction or a new harness and ecu?? thanks alot
crookson speed
02-21-2017 06:08 PM
crookson speed
02-19-2017 04:30 PM
