Headlight differences...
Old 12-06-2008, 10:46 PM
Clipsed's Avatar
Default Headlight differences...
OK, so I searched and didn't find an exact answer to my question, came close, but still no luck..
My question is... Is there a difference in the SHAPE of a JDM 90-91 hatch headlight than that of the USDM 90-91 headlight. I know that the hatch, rex, and sedan headlights are all the same (USDM), only they utilize different mounting brackets and the brackets differentiate from 88-89 and 90-91.
I found this post in another thread...
Originally Posted by kojack_0
this is to solve any arguments, disagreements, and debate about the headlight fitment on the 88-91 civic 3/4dr and 88-91 crx
_______________________________________
88-89 crx headlight assembly:
90-91 crx headlight assembly:
88-89 civic 3/4dr headlight assembly:
90-91 civic 3/4dr headlight assembly:
88-89 crx corner light:
90-91 crx corner light:
88-89 civic hatch corner light:
90-91 civic hatch corner light:
88-89 civic sedan corner light:
90-91 civic sedan corner light:
________________________________________
jdm civic hatch headlight:
jdm crx headlight:
jdm civic sedan headlight:
1. notice how the headlights itself between crx, hatch and sedan are all THE SAME.
2. notice how the 'buckets'/mounting brackets itself between crx, hatch and sedan differ from the years.
3. notice how the coner lights itself between crx, hatch and sedan mounts the same way. [88-89 two screws; 90-91 one screw on the tab]
4. notice the crx corner lights are 'evenly' curved.
5. notice the hatch corner light have one sharp corner than the crx.
6. notice the sedan corner light have one sharp corner, BUT shorter than the crx or hatch.
7. notice that both the jdm crx headlight and jdm hatch headlight are the same.
8. notice that the jdm sedan headlight has the corner light and headlight as a 1-piece design.
9. notice that both the jdm crx and jdm hatch headlight uses one light bulb.
10. notice that the jdm sedan headlight STILL uses two light bulbs? [correct me if im wrong]
any corrections let me know.
Now my question is, if it is possible to utilize USDM headlights with an SiR front end.
Old 12-06-2008, 11:25 PM
D16SiHatch's Avatar
nope. you have to use jdm headlamps
Old 12-06-2008, 11:29 PM
frank_el_tanke's Avatar
you should be able to. however, the jdm headlights are a little bit longer,by longer i mean closer to each other, so if you use the jdm hood there will be a gap between the hood and the headlights.
Old 12-06-2008, 11:35 PM
Clipsed's Avatar
Thanks, that's what I needed to know... And you can't use the USDM hood with the JDM front either huh??
Old 12-06-2008, 11:45 PM
nope.
Old 12-06-2008, 11:49 PM
91Hatcher's Avatar
i have accord headlights on my ef! they are bigger so it looks cool and it fills in really good and i think they are a bit brighter as well.
Casey
Old 12-07-2008, 12:07 AM
EFB055
~sp33~'s Avatar
Pictures?
Old 12-07-2008, 02:16 AM
My_EFsedan's Avatar
the "88-89" sedan corner is wrong. that one is also an 88-89 hatch.
Old 12-07-2008, 07:13 AM
buggs's Avatar
JDM EF3 headlights have the same shape and size as the EDM EC/ED Civic and all USDM hatchbacks.
The difference is to be found on the SIR / VTEC models. As the previous poster told they wont fit to your USDM frontend.
Here you can see the differences in shape and size:
Theese are all hatchback head lights!
Old 12-07-2008, 08:05 AM
Jonknee's Avatar
Damn look at the header clearance on the crx lmfao
Old 12-07-2008, 08:09 AM
buggs's Avatar
What CRX :eek:
Old 12-07-2008, 09:05 AM
88 EF Hatch's Avatar
Jdm front end is so tight cuz
Old 12-07-2008, 10:40 AM
Clipsed's Avatar
thanks guys, that makes all my questions answered!
RanCRX
07-12-2009 04:22 PM
15wikCed13
06-14-2009 06:11 PM
Pooby88
01-10-2006 07:34 AM
sm00thk0zz
09-13-2004 11:06 AM
Kin
02-24-2002 07:42 PM
Quick Reply: Headlight differences...
