h22 with a b series tranny?????
Old 02-09-2006, 07:04 PM
levee000's Avatar
Default h22 with a b series tranny?????
i was wanting to know if any one knows who sells the plate to do the h22 on a b series tranny i wold like to do it adn would like some info on it thx
Old 02-10-2006, 03:10 PM
hb_guy's Avatar
Default Re: h22 with a b series tranny????? (levee000)
i have heard something about this myself and i'm curious too... anyone?
Old 02-10-2006, 08:49 PM
skunked's Avatar
Default Re: h22 with a b series tranny????? (hb_guy)
http://www.QuarterSportsDrag.com
Old 02-10-2006, 09:45 PM
hb_guy's Avatar
Default Re: h22 with a b series tranny????? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">http://www.QuarterSportsDrag.com
nice!!! i am going to call on monday!!
Old 02-11-2006, 04:58 AM
h224thgensedan's Avatar
This is the way that i am swapping my h. You need mounts for a b linkage and axles all for a b. You need to make a custom driver side mount. You need a b series clutch and flywheel. Convert your wirring up to obd1 and run the vtec. For the crank pully you will need to cut out for it on the driver side finder well. It would be best to make an alt. bracket to fit in front of the motor on top so its easier to change. As for weight dont let those people that say its to heavy talk you out of it. Its heavier but not by much at all. With b series gearing you can be in 13's with a stock motor. If you guys have anyother questions i will try and answer them for you.
Old 02-11-2006, 08:33 AM
i hate rice's Avatar
what kinda car do you have. cause I've talked to that guy before. and clearance is a big isue for a lot of cars. and if that's gonna be your daily driver i would suggest it. cause you may have to cut out some of the Chasse(spelling?) to make it work. also your hood might be in the way cause it cause to motor to sit straight up and down. but if you have a big body car it wont matter but your not getting that **** in a hatchback or crx lol
Old 02-11-2006, 09:18 AM
SoClose's Avatar
it would be nice if someone did a new thread on itz . .
Old 02-11-2006, 09:36 AM
K-Drum's Avatar
here is the pictures of a friends of mines swap in progress.
Old 02-11-2006, 09:48 AM
STEV3-O's Avatar
Default Re: (K-Drum)
I believe on DA's and ef chassis require cuttin the chassis for clearance... i might be wrong, and eg/ek/dc chassis only require spacers on the hood, and doing something with the crank pulley, correct me if im wrong.
Old 02-11-2006, 09:59 AM
K-Drum's Avatar
I know a hood for sure is required, Cowl style would work well with ITB's tough...
Old 02-11-2006, 01:12 PM
SIXTY's Avatar
That engine bay is teh dirt!
Old 02-11-2006, 08:30 PM
31flavorscivic's Avatar
Default Re: (sixty-seven point six)
Anyone know the price on that? The website said call.
Old 02-12-2006, 03:10 AM
The plate is 900 plus shipping for a crx/civic. As for the cutting and hacking you have to shave a little off of the back of you block, and you have to cut out the finder well on the inside of the engine bay because the crank pully hits it. Instead i am just going to weld a new bolt pattern onto the b series tranny that way i will not need an adapter plate. Also that should allow me to not need to cut the finder well for clearance. As for the hood you can shim the back of yours up, get a custom hood, and i have seen them clear the jdm hoods with no problems. I have also seen ones that needed a 4 inch cowl to clear.
BlueRex1020
01-29-2007 05:31 PM
vteczone
11-13-2006 06:26 AM
boostedbseries2000
07-11-2006 08:27 AM
mikecivichb
09-01-2005 02:28 PM
pete332
02-23-2003 08:28 PM
Quick Reply: h22 with a b series tranny?????
